PIC16F1828, "Symbol not previously defined (CCPTMRS0)", need help!
Results 1 to 11 of 11
    Nov 2009
    DFW area of Texas
    Default PIC16F1828, "Symbol not previously defined (CCPTMRS0)", need help!
    PIC16F1828 has register for assigning the Timer2's to CCP modules named: CCPTMRS0 (that's a zero at the end).
    I'm trying to set it using:
    CCPTMRS0 = %00000110
    But this line is throwing these errors in compilation:
    Error[113] c:\pbp\pbppi14e.lib 583: Symbol not previously defined (CCPTMRS0)
    Error[113] c:\pbp\pbppi14e.lib 918: Symbol not previously defined (CCPTMRS0)
    Does this have to do with which bank to find CCPTMRS0?
    PIC16F1828 datasheet shows CCPTMRS0 in bank5.
    I'm using PicBasicPro2.6c
    Thanks in advance!
    -ray
    "Imagination is more important than knowledge", Albert.E.
    Nov 2009
    DFW area of Texas
    Default Re: PIC16F1828, "Symbol not previously defined (CCPTMRS0)", need help!
    The 16F1828.bas file contains only this:
    BANK0 $0020, $007F
    BANK1 $00A0, $00EF
    BANK2 $0120, $016F
    EEPROM $F000, $F0FF
    LIBRARY "PBPPI14E"
    DEFINE CODE_SIZE 4
    include "PI14EEXT.BAS"
    PORTL VAR PORTA
    PORTH VAR PORTC
    TRISL VAR TRISA
    TRISH VAR TRISC
    include "PBPPI14E.RAM"
    -ray
    Nov 2009
    DFW area of Texas
    CCPTMRS = %00000110 doesn't throw a compiler error; and this register does not exist on the PIC16F1828 data sheet nor in the Errata.
    (maybe it's a mistake where CCPTMRS0 should be CCPTMRS in the data sheet) ?
    ..trial and error...
    -ray
    This error was fixed in PBP 3.0.0.0 (Aug 2011)
    There is no patch for 2.60, but you can set the CCP registers directly instead of using HPWM.
    Nov 2009
    DFW area of Texas
    I am not using the PBP HPWM call, I am setting up the CCPs in PWM mode manually in the order the PIC16F1828 datasheet states,
    I tried this code:
    OSCCON = %11101000 '4Mhz intosc
    Define OSC 4 'software timers indicated for 4mhz operation
    TRISA = %00011011'Tris register 1=input(PORdefault) 0=output
    TRISB = %00110000'No Vref's used on ADC
    TRISC = %10000111
    ANSELA = %00010011'Ansel register 1=analog 0=digital
    ANSELB = %00010000
    ANSELC = %10000111
    CCPTMRS0 = %00000110'Timer2/4/6 assignment to CCP modules(pulsed output pins)
    Start:
    TRISC.3=1 'Disable pin output, set as input
    PR4=200 'Set Period Rate, PRx, in Timer
    CCP2CON=%00001111 'Turn on PWM
    CCP2CON.5=1 'high bit of 2LSBs of Duty
    CCP2CON.4=0 'low bit of 2LSBs of Duty
    CCPR2L=180 '8MSBs of Duty
    PIR3.1=0 'clear Timer interrupt flag
    T4CON.1=1 'high bit of 2bit Timer Prescaler
    T4CON.0=1 'low bit of 2bit Timer Prescaler
    T4CON.2=1 'Timer On
    TRISC.3=0 'Enable pin output
    the compiler throws this error:
    -ray
    Nov 2009
    DFW area of Texas
    Red face Re: PIC16F1828, "Symbol not previously defined (CCPTMRS0)", need help!
    MOVE?CB 006h, CCPTMRS0
    is put into the .asm file eventhough the error is shown in Microcode Studio
    (I don't even know why I'm telling you this, but I figured it may help)
    -ray
    Nov 2009
    DFW area of Texas
    Can you please give me some code to use for loading a value into CCPTMRS0 manually on the PIC16F1828.
    The data sheet shows its in memory map location:
    Bank5
    29Eh
    CCPTMRS0
    Thanks in Advance!... And I'm working on purchasing PBP3.0 as well.
    -ray
    I'm not sure this is the case but I think it might be an MPASM include file issue.
    It looks like CCPTMRS and CCPTMRS0 registers are one and the same (they are defined that way (at 0x029E) in my version (5.47) of the MPASM .inc file) so it's possible that your version of the .inc file is missing the CCPTMRS0 regsiter definition.
    So, try using CCPTMRS instead of CCPTMRS0 or you can try adding...
    CCPTMRS0         EQU  H'029E'
    ...at the very beginning of your code.
    Nov 2009
    DFW area of Texas
    DT is correct, after trying several variants of ASM code that didn't work; I was buying and downloading the PBP3.0.
    The PBP3.0 is nicely packaged! Download the 128Mb flavor with all the new MPASM/Microcode Studio stuff...and you may need to get the latest Beta programmer software for newer PICs.
    The multiple hardware PWMs on the PIC work from the multiple Timer2's now that I used PBP3.0
    $$ well spent, and for a good cause to keep the PB biz going!
    I still have a problem with keeping the hardware PWM going, it stops when I use HSER or ADC on other pins, eventhough the hardware PWM is coming out of a default ccp pin(that is not eusart by default)
    ..I haven't figured it out yet..
    thanks all !!
    -ray
    Nov 2009
    DFW area of Texas
    Ok, the hardest problems are the one's when you are the problem yourself.
    I had an error in a supporting device's code, fixed it, and now all works good.
    BUT,
    It would not be possible without using the PBP3.0
    thanks DT !
    -ray
    Nov 2009
    DFW area of Texas
    Thank you Olsson!!, that work-around is on the right track and I tried a few attempts as such, but no success.
    The PBP3.0 works good and worth the $$ IMO.
    all the best!
    -ray
  1. Replies: 0
    Last Post: - 14th November 2013, 03:32
  2. Replies: 3
    Last Post: - 15th October 2012, 08:06
  3. "symbol not previously defined" on 16F1933 - fuse issue i think
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2011, 03:24
  4. Symbol not previously defined
    By Archangel in forum Code Examples
    Last Post: - 27th December 2008, 09:52
  5. Replies: 1
    Last Post: - 16th February 2005, 20:05
