Config error.
Results 1 to 4 of 4
Thread: Config error.
    Dec 2013
    Default Config error.
    Hi all, i have a problems when I try to use a external oscillator.
    in the pic 12f683 I'm using the next instruction for use a HS oscillator:
    @__CONFIG_ _HS_OSC;
    and in the 16f88 I'm using this:
    @ CONFIG CONFIG1, HS OSC;
    @ CONFIG CONFIG2, IESO OFF & FCMEN OFF;
    when I compile in both programs send an error message like this:
    __CONFIG directives cannot be used with CONFIG directives
    Someone know what i'm doing wrog?
    a lot of Thanks.
    Default Re: Config error.
    Which version of PBP and assembler do you use?
    Edit: http://www.picbasic.co.uk/forum/showthread.php?t=543
    Dec 2013
    I'm using MPASM in microcode, I already correct that error, but now i have another problem, I use this instruction:
    @ include "p16f88.inc"
    @ __CONFIG _CONFIG1, _HS_OSC
    @ __CONFIG _CONFIG1, _HS_OSC;
    in both programs apppear this error:
    Overwritting previous adress contents (2007)
    Do you know how to fix it?
    Quote Originally Posted by Gerardo View Post
    Since you have already found this thread: http://www.picbasic.co.uk/forum/showthread.php?t=543
    I would suggest you go back and read it, paying special attention to post 5
  1. ERROR line 90: Sintax error----> [TabIndex]
    By martintorres in forum mel PIC BASIC Pro
    Last Post: - 9th September 2012, 04:29
  2. Replies: 1
    Last Post: - 30th March 2012, 04:13
  3. Config Error message
    By sinoteq in forum mel PIC BASIC Pro
    Last Post: - 12th July 2010, 11:08
  4. Compiler Error EMM Command line in Config.nt
    By Boots in forum FAQ - Frequently Asked Questions
    Last Post: - 16th February 2005, 05:32
  5. Compiler Error: EMM Comand Line in Config.nt
    By Boots in forum mel PIC BASIC
    Last Post: - 13th February 2005, 04:37
