PIC 16F819 Turn-On Problem
Results 1 to 11 of 11
    Bruce,
    PWRT is already disabled. Here is the whole configuration line:
    @device pic16f819,intrc_osc_noclkout,wdt_on,pwrt_off,mclr_ off,bod_off,lvp_off,cpd_off
    @ device ccpmx_off,debug_off,wrt_off,protect_off
    I will try M's cap fix. The approach makes sense because it creates a transient path to gnd for the spurious voltage. Can't do this right away though...will have to wait.
    Dick
    Jun 2005
    Post
    Dick,
    Did you ever solve your 16F819 Turn-On problem?
    Like Bruce recommended, I have found the PWRT seems to help.
    I am also using INTRC and initialize to OSCcon = $60 (4mhz) and
    later switch to OSCcon = $70 (8mhz) at the end of my initialization,
    just before my main loop.
    I have used 16F627A with INTRC, and 16F876, 16F872 w/ crystal and never had power up Turn-On problem like the 16F819.
    Mark
    Hi Dick. I had exactly the same problem with a 16LF818 attached to a music chip. Upon power-up the chip would blast a few milliseconds of music from the speaker. I cured the problem by turning "POWER UP TIMER OFF". It's been about a year now and no problems have arised by doing this.
    Peter and Mark,
    No, I never really solved the problem, and yes, the power-on timer is already set to off as explained earlier. I have now moved past the problem because I no longer use the super-fast solenoid. Have gone to a servo instead .. no problem.
  1. Trouble with most basic BLINK on PIC 16F819
    By confusedperson in forum mel PIC BASIC Pro
    Last Post: - 16th April 2009, 22:46
  2. Help with PIC project
    By davekav in forum General
    Last Post: - 18th April 2008, 00:15
  3. Button problem driving me crazy!! Please help!
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 20th November 2007, 15:46
  4. Serin Problem 16f819
    By jjohannson in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 23:50
  5. Circuit needed to allow a PIC to turn something on or off
    Last Post: - 12th October 2005, 22:17
