Help for a new boy
Results 1 to 8 of 8
    Dec 2013
    Default Help for a new boy
    Hi All
    A bit new to all this but learning fast (I hope), and this seems a stupid question, but I don't know and if you don't know you have to ask so........
    I have code which works fine on a 12f683, but I had originally planned to use 12f629 and so want to recode it. Now I know there are certain differences, but at the moment I cant even get simple code to work on the 629.
    I have this that works on the 629
    ' Name        : Test44.pbp
    ' Compiler    : PICBASIC PRO Compiler 3.07
    ' Assembler   : PM
    ' Target PIC  : 8-pin PIC12F629
    ' Oscillator  : 4MHz internal
    ' Description : test file PICBASIC PRO program to show button press on LED.
    DEFINE PIC12F629, INTRC_OSC,INTRC_OSC_NOCLKOUT,WDT_ON,PWRT_ON,MCLR_OFF, BOD_ON , CPD_OFF , PROTECT_OFF
    Define OSCCAL_1K 1 ' PIC12F675, Calibrate internal oscillator
    CMCON = 7      ' Analog comparators off
    CLEAR
    LED var gpio.1        ' Alias GPIO.0 to LED
    PB  Var GPIO.0   ' Alias GPIO.3 to push button
    ' Button press turns on LED
       If PB = 0 Then ' If button pressed...
         low LED      ' Turn on LED
       Else
         high LED     ' Turn off LED
       Endif
       Goto mainloop  ' Do it forever
    However if I add lines after "'Button press ...." such as a short HIGH/PAUSE/LOW/PAUSE sequence all I get is the Led going High and the Prg appears to halt.
    If I try similar code on the 683 it works - dont even have the opening DEF in there
    Any help gratefully received
    Confused Colin
    Bombay, India
    Default Re: Help for a new boy
    Colin
    You haven't defined the label for 'mainloop' and tell the processor to goto mainloop. You're probably getting errors while compiling this code.
    Please tell us what version of PBP you are using, and if you know whether you are using MPASM or not.
    Good catch Jerson . . .
    Dec 2013
    just checked the code and have got mainloop defined - don't why it didn't copy over.
     ' Name        : Test44.pbp
    ' Assembler   : PM
     'Button press turns on LED
    mainloop:
       Else
       Endif
    I am using PBP3.071 and and I guess MPASM if that is the default installed.
    It will be easier for members to help if you post all your code. You don't have any CONFIGs, no oscillator setting, LED is not defined as a beginning.
    Are the proper pins digital by default on this device?
    Dec 2013
    The earlier code posted has all the detail
    Led var GPIO.1 etc
    DOES NOT WORK IN pbp3.xxx which is why I asked you, in fact it does not work in MPASM with ANY version of PBP as it is for the PB assembler which PBP3.xx does not support.
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BOR_OFF & _FCMEN_OFF & _IESO_OFF
    above would be how to config MPASM in PBP versions earlier than PBP3.00
    PBP 3.xx configs are done as in below:
        __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_ON & _WDT_ON
    ;__config _CONFIG2, _WRT_OFF & _BOR40V
    All that said you will need to make appropriate changes to what I posted for your particular chip, but that is how to format your configs
    Dec 2013
    Thanks for the config help
  1. Replies: 2
    Last Post: - 26th February 2011, 16:56
  2. Boy, what a great place this is!!!
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 17th June 2007, 18:42
