Question: PICs with two configuration words versus one, e.g., 16F88 versus 12F683
Results 1 to 5 of 5
    Jan 2013
    Default Question: PICs with two configuration words versus one, e.g., 16F88 versus 12F683
    Please show me how to organize the configuration bits for PICs with more than one configuration word in the same format that they can be organized for PICs with a single configuration word. There are two code samples: one is for a 12F683 and the configuration bits are organized the way I like to see them; the second is for a 16F88 and the configuration bits are in a long string, but I would like to know how to organize them like they are organized in the 12F683 file. Thanks
    ' Name: 16F88 Blink1.pbp
    ' Compiler: PICBASIC PRO Compiler 3
    ' Assembler: MPASM
    ' Author:
    ' Target PIC: 16F88
    ' Hardware: CRH Breadboard
    ' Oscillator: 4MHz Internal
    ' Date: 10 Dec 2013
    ' Description:
    'Device Configuration
    #IF __PROCESSOR__ = "16F88"
    #config
     __CONFIG    _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_ON & _WDT_OFF & _INTRC_IO
     __CONFIG    _CONFIG2, _IESO_OFF & _FCMEN_OFF
    #else
    #MSG "Wrong microcontroller selected!"
    #endif
    'Register Initialization
    TRISB = %11111110          ' Sets up RB0 pin of PORTB as an output
                            ' and pins RB7-RB1 of PORTB as inputs
    OSCCON = $60            ' Sets the internal oscillator in the
                            ' 16F88 to 4 MHz
    'Main Code
    start:              ' Label for beginning loop
         PORTB.0 = 1        ' Makes pin PORTB.0,(RB0), output HIGH (+5 volts)
        Pause 500        ' Pause 500 milliseconds (0.5 seconds) with LED on
        PORTB.0 = 0        ' Makes pin PORTB.0,(RB0), output LOW (0 volts)
        Pause 500        ' Pause 500 milliseconds (0.5 seconds) with LED off
        GoTo start        ' Jump to loop label
                        ' Makes the program run forever.
        End                ' This line is in case the
                        ' the program gets lost.
    ' Name: 12F683 HPWM.pbp
    ' Assembler: MPASM
    ' Author:
    ' Target PIC: 12F683
    ' Oscillator: 8MHz Internal
    ' Date: 1 Nov 2013
    ' Description:
    ' Device Configuration:
    #IF __PROCESSOR__ = "12F683"
    #config
    cfg1 = _INTRC_OSC_NOCLKOUT  ; Internal oscillator
    cfg1&= _WDT_OFF             ; Watch Dog Timer disabled
    cfg1&= _PWRTE_ON            ; Power-up Timer enabled
    cfg1&= _MCLRE_OFF           ; Master Clear Reset disabled
    cfg1&= _CP_OFF              ; Program Code Protection disabled
    cfg1&= _CPD_OFF             ; Data Code Protection is disabled
    cfg1&= _BOD_OFF             ; Brown-out Detect disabled
    cfg1&= _IESO_OFF            ; Internal External Switchover mode disabled
    cfg1&= _FCMEN_OFF           ; Fail-safe Clock Monitor disabled
     __CONFIG  cfg1             ; Set the configuration bits
    #else
    #endif
    ' Register Initializations:
    ADCON0  = 0
    ANSEL   = 0
    CMCON0  = 7           ' Comparators off.
    TRISIO  = 0
    GPIO    = 0
    OSCCON  = %01110001   ' Internal 8MHz osc.
    CCP1CON = %00001100   ' CCP1, PWM mode
    CCPR1L  = 0
    T2CON   = %00000101   ' TMR2 on, prescaler 1:4
    PR2     = 250         ' Set the PWM period.
    ' Includes:
    ' Defines:
    DEFINE OSC 8
    ' Constants:
    ' Variables:
    ' Aliases and modifiers:
    Speed var CCPR1L
    Btn Var GPIO.4  ' Assuming ; the pin is pulled down to GND by 10K resistor, and button pulls it high to Vdd.
    ' LED is connected to GPIO.2 (on board PWM module)
    ' Program Code:
    pause 10
    Start:
        if btn then
            if speed + 51 < 256 then    ' 0, 51, 102, 153, 204, 255 0
                speed = speed + 51
                speed = 0
            while btn : pause 20 : wend
        pause 2
    goto Start
    Default Re: Question: PICs with two configuration words versus one, e.g., 16F88 versus 12F683
    Tracecom, Either way is acceptable, There are 2 configuration words for the F88 processor. There are even more for some of the higher end processors. I don't understand the question?
    EN82fn
    Jan 2013
    Thanks for the response. I know that both ways work, but I want to use the same style layout for the 16F88 as for the 12F683. I have tried several times to rearrange the 16F88 configuration in a vertical list instead of a long horizontal string, but can't get it to compile.
    cfg1 = _INTRC_IO               ; Internal Oscillator
    cfg1&= _CP_OFF                 ; Code protection OFF
    cfg1&= _CCP1_RB0               ; CCP1 function on RB0
    cfg1&= _DEBUG_OFF              ; In-Circuit Debugger Disabled
    cfg1&= _WRT_PROTECT_OFF        ; Flash Program Memory Write Enable bits
    cfg1&= _CPD_OFF                ; Data EE Memory Code Protection Disabled
    cfg1&= _LVP_OFF                ; Low Voltage Programming Disabled
    cfg1&= _BODEN_OFF              ; Brown-out Reset Enable bit
    cfg1&= _MCLR_OFF               ; Master Clear Reset Disabled
    cfg1&= _PWRTE_ON               ; Power-up Timer Enabled
    cfg1&= _WDT_OFF                ; Watch-Dog Timer Disabled
       __CONFIG    _CONFIG1, cfg1  ; -- Set config word 1
    cfg2 = _IESO_OFF               ; Internal External Switchover Disabled
    cfg2&= _FCMEN_OFF              ; Fail-Safe Clock Monitor Disabled
       __CONFIG    _CONFIG2, cfg2  ; -- Set config word 2
    Jan 2013
    Thank you, Darrel.
  1. SPI configuration PIC versus Atmel
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 10th July 2007, 20:17
  2. A/D versus Digital I/O
    By dallennn in forum mel PIC BASIC Pro
    Last Post: - 11th November 2006, 05:31
  3. lcdout versus serout2
    By Fred in forum mel PIC BASIC Pro
    Last Post: - 28th September 2006, 14:14
  4. Pulsin versus While Wend
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 7th March 2006, 21:08
  5. PM assembler versus MPAsm
    By bwarb in forum mel PIC BASIC Pro
    Last Post: - 16th August 2005, 17:14
