How to write port names into array ?
Results 1 to 29 of 29
    Default Re: How to write port names into array ?
    Sure, this is way better, but still not exactly what I want. Since it utilizes loop and constant subroutine calls. I want to have defined the array in the beginning of the code, and access it as needed.
    So are you looking to . . .
    AC5 var PORTC.5
    AC4 var PORTC.4
    AC3 var PORTB.3
    AC2 var PORTB.1
    AC1 var PORTB.5
    AC = %00010101
    and then have the listed ports go high according to the declaration above?
    If SO try AC = ~~%00010101
    Apr 2011
    Welches, Oregon
    Perhaps I misunderstood your inquiry; it is difficult with so little explanation...
    Perhaps you mean:
    'DEFINE ARRAY
    AC var bit[7]
    'ASSIGN ALIAS
    SYMBOL AC[5] = PORTC.5
    SYMBOL AC[4] = PORTC.4
    SYMBOL AC[1] = PORTB.5
    'LOOP THRU VALUES
    FOR LOOP = 5 to 1 STEP -1
    AC[LOOP] = Some assigned bit value
    Next LOOP
    Of course, the bit array may be expanded to include as many elements as you need and you may SYMBOL each element to any port or single bit variable you like to access them through a loop - which need not begin at the first element nor continue through the last.
    You mention ARRAYWRITE, but if the answer was there you would certainly have seen that in the manual, yes?
    Yes, I want to put different port names into array, so when needed, I can read or address them sequentally.
    So what I want to do, I'll write a code in some imaginary basic, a bit short code that will do a running led light:
    DIM LEDS(3) 'define array with 3 entries
    LET LEDS(1)=PORTA.2
    LET LEDS(2)=PORTB.3
    LET LEDS(3)=PORTC.1 'enter data into array
    FOR A=1 TO 3
    HIGH LEDS(A)' make pin high
    pause 500 ' wait some time
    LOW LEDS(A) 'make pin low
    NEXT A
    So I wrote it in this way, but it does not works:
    AC VAR BIT[5]
    AR VAR BIT[7]
    AC[5]=PORTC.5
    AC[4]=PORTC.4
    AC[3]=PORTB.3
    AC[2]=PORTB.1
    AC[1]=PORTB.5
    AR[1]=PORTB.6
    AR[2]=PORTC.7
    AR[3]=PORTB.2
    AR[4]=PORTB.0
    AR[5]=PORTB.4
    AR[6]=PORTB.7
    AR[7]=PORTC.6
    'make all leds connected to ports on.
    low ac[1]
    low ac[2]
    low ac[3]
    low ac[4]
    low ac[5]
    high ar[1]
    high ar[2]
    high ar[3]
    high ar[4]
    high ar[5]
    high ar[6]
    high ar[7]
    'but it does not works
    'but it works with code below
    low PORTB.3
    HIGH PORTC.7
  1. Setup port pins into an array
    Last Post: - 25th April 2013, 17:24
  2. Assign different port bits to an array?
    By vamtbrider in forum mel PIC BASIC Pro
    Last Post: - 30th November 2010, 03:40
  3. Why (or how to) make a port array for OW
    By Roy___ in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2009, 00:30
  4. array and port
    By piombazzo in forum mel PIC BASIC Pro
    Last Post: - 9th November 2008, 21:58
  5. Replacing an ARRAY with EEPROM write to save space?
    Last Post: - 12th March 2005, 19:31
