Multiple PWM and port C
Results 1 to 24 of 24
    Oct 2009
    Default Re: Multiple PWM and port C
    OK guys you've lost me.
    I think the work around for now is to simply use pins D1 and D2 as the output and solder links on the PCB - This way I get a working solution of true square wave of 0-5v running at a frequency that suits the LED drivers, and code that runs at a suitable speed.
    Thanks again for all your input....
    Have you tested different caps to filter that noise on square waves?
    Oct 2009
    Ok, for the past few days I've been running the code on the development board using D2 and D3 as the output pins for the PWM - all was fine so I placed the chip in the controller and over the weekend it's been running fine, and with the added bonus that the LDD LED drivers don't sing like they used to when using the hardware generators on the PIC.
    So I've now started to add in the next module for the project, serial communications. Thanks to Robert's post in my other thread I've used MisterE's tool to generate the port definitions etc, and after a slight hardware issue with the USB/serial cable used a simple echo program to test the comms - it worked fine, using the Comms tool in Microcode Studio I was able to connect to the port, and whatever I sent from the PC was echoed back in the RX panel...I then opened the current working version of my code and simply inserted the line
    Hserout ["Blues  ",DEC(B_PWM * 100)/255, 13, 10] ' Send text followed by carriage return and linefeed
    which should simple send the value of B_PWM as a percentage to the PC. However when I compiled the code and ran it, then set the clock to the time the lights were on, the PWM remained at 0 and didn't increase. The RTC ran, and the menu options worked so the code was looping, but for some reason I never got an output from the software pins or the LCD. If I commented out the Hserout line the code works perfectly.
    It seems another conflict when running DT's multi_pwm with port C, and again its coms related.
    Oct 2009
    Uhmmmm
    Adding a pause 1000 after the line seems to of resolved the issue (head scratch !!!)
  1. Multiple PWM pins
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 17th November 2013, 19:23
  2. Darrel's Multiple Software PWM
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 15th October 2013, 15:21
  3. Drive multiple LED with one PWM
    By microuser in forum General
    Last Post: - 27th September 2007, 13:26
  4. Multiple Pics to One serial port
    By Rleonard in forum Serial
    Last Post: - 18th January 2007, 18:30
  5. Multiple IR LEDs from 1 port using transistor
    By belpe123 in forum General
    Last Post: - 20th May 2005, 22:07
