Multiple PWM and port C
Results 1 to 24 of 24
    Oct 2009
    Default Re: Multiple PWM and port C
    I've just tried cutting and pasting the code into a new page and renamed it - complied and loaded and got the same results when using C1 and C2 as the PWM pins. If I comment out the include "Multi_SPWM.pbp" the program runs fine, but I obviously have no outputs from the two pins.
    So maybe you're right Henrik, in that there is some clash with the timing / or i2c bus ???
    Since it seems to work when you're using SPWM on one port (PortB for example) while the I2C is on another (PortC) I don't think it's a timing thing.
    Since it does NOT seem to work when the SPWM is on the SAME port as the I2C I think it's some other sort of interference where the SPWM is messing with the I2C pins, possibly due to R-M-W but I don't know for sure.
    As for the hardware PWM....
    The original code had
    'Send pulses to drivers
        hpwm 1,W_PWM,200
        hpwm 2,B_PWM,200
    Well, then that IS the problem you're having - you're trying to run it at TO LOW frequency, which was the point I was trying to make.
    At 20MHz oscillator frequency there is no way to actually get 200Hz from the CCP module, the lowest possible frequency is 1221Hz.
    Oct 2009
    Ok I've tried a different approach. I noticed that Darrel has revised his multiple PWM Routine Called SPMW_INT rather then the Multi_SPWM So I modified a fresh copy of the code, included that file and the DT_INTS-18 file and the thing compiled. Loaded it to the chip and both the TEMP and CLOCK are acting up. The temp is shown as 163c and the clock as 45:85.
    Here's the main part of the revised code
      __CONFIG    _CONFIG1H, _OSC_HS_1H
      __CONFIG    _CONFIG2L, _PWRT_ON_2L
      __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H
      __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    INCLUDE "DT_INTS-18.bas"            ; Base Interrupt System
    INCLUDE "SPWM_INT.bas"              ; Software PWM module
    DEFINE SPWM_FREQ  200                ; SPWM Frequency
    DEFINE SPWM_RES   256               ; SPWM Resolution
    SPWM_LIST  macro                    ; Define Pin's to use for SPWM
         SPWM_PIN  PORTC, 1, _B_PWM  ; and the associated DutyCycle variables
         SPWM_PIN  PORTC, 2, _W_PWM  ; Notice the underscore before variables
      SPWM_INIT  SPWM_LIST              ; Initialize the Pins
            INT_Handler   TMR1_INT,  SPWMhandler,  ASM,  yes
        INT_CREATE                      ; Creates the interrupt processor
    @ INT_ENABLE  TMR1_INT              ; enable Timer 1 interrupts
    INCLUDE "LCDbar_INC.bas"        ' Include the BARgraph routines
    DEFINE LCD_DREG  PORTB                  ' LCD Data port
    DEFINE LCD_DBIT  0                      ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB                  ' LCD Enable port
    DEFINE LCD_EBIT  5                      '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB                  ' LCD Register Select port
    DEFINE LCD_RSBIT 4                      '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4                      ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4                      ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000               ' Command delay time in us
    DEFINE LCD_DATAUS 50                    ' Data delay time in us
    DEFINE  OSC 20                          ' 18F4520, 20mhz crystal
    ADCON1 = $0F
    clear
    'DS18B20 temp probe setting
    DQ              VAR     PORTA.5         ' One-wire data pin
    temperature     VAR     WORD            ' Temperature storage
    count_remain    VAR     BYTE            ' Count remaining
    count_per_c     VAR     BYTE            ' Count per degree C
    'Port and Register settings
    TRISA  = %11101111
    TRISB  = %00000011
    TRISD  = %00000011
    T0CON  = %11000111
    ADCON0 = %00000000;          // AD converter module disabled
    ADCON1 = %00001111;          // All Digital
    ADCON2 = %00000000;          //
    CMCON = 7
    ' Data presets
    data @0
        data    00                          'Blue fade IN duration hours
        data    5                          'Blue fade IN duration minutes
        data    00                          'Blues fade OUT duration hours
        data    45                          'Blue fade OUT duration minutes
        data    00                          'Whites fade IN duration hours
        data    7                          'Whites Fade IN duration MINS
        data    00                          'Whites Fade OUT duration HOURS
        data    20                          'Whites Fade OUT duration MINS
        data    255                         'Blue MAX Intensity %
        data    255                         'Whites MAX Intensity %
        data    word 840                    'Blue ON time 14:00
        Data    word 840                    'Whites ON time 14:00
        data    word 1200                   'Blue OFF time  20:00
        Data    word 1200                   'White OFF time 20:00
        Data    word 1200                   'Sump light on time  20:00
        Data    word 1200                   'Sump light off time  8:00
    ' Variables
    fadesetHR          VAR WORD[2]
      fadesetHR1       VAR fadesetHR[0]     'blue fade in hour
      fadesetHR2       VAR fadesetHR[1]     'White fade in hour
    fadesetMN          VAR WORD[2]
      fadesetMN1       VAR fadesetMN[0]     'blue fade in minutes
      fadesetMN2       VAR fadesetMN[1]     'white fade in minutes
    fadeoutHR          VAR WORD[2]
      fadeoutHR1       VAR fadeoutHR[0]     'blue fade out hour
      fadeoutHR2       VAR fadeoutHR[1]     'white fade out hour
    fadeoutMN          VAR WORD[2]
      fadeoutMN1       VAR fadeoutMN[0]     'blue fade out minute
      fadeoutMN2       VAR fadeoutMN[1]     'white fade out minutes
    lightsetHR          VAR word[2]
      lightsetHR1       VAR lightsetHR[0]   'blue on time hour
      lightsetHR2       VAR lightsetHR[1]   'white on time hour
    lightsetMN          VAR word[2]
      lightsetMN1       VAR lightsetMN[0]   'blue on time minutes
      lightsetMN2       VAR lightsetMN[1]   'white on time minutes
    lightoffHR          VAR word[2]
      lightoffHR1       VAR lightoffHR[0]   'blue off time hour
      lightoffHR2       VAR lightoffHR[1]   'white off time hour
    lightoffMN          VAR word[2]
      lightoffMN1       VAR lightoffMN[0]   'blue off time minutes
      lightoffMN2       VAR lightoffMN[1]   'white off time minutes
    DecButton var PORTA.0	                ' Press to Decrement Button
    SetButton var PORTA.1                   ' Press to Set/memorise Button
    IncButton var PORTA.2	                ' Press to Increment Button
    OnButton var PORTA.0	                ' Press to Decrement Button
    OffButton var PORTA.2	                ' Press to Increment Button
    H_butt   VAR PORTA.2                    'hour increase
    M_butt   VAR PORTA.0                    'minutes increase
    S_butt   VAR PORTA.1                    'set / memorise
    Counter1 var word                       'used to store the current time as a digit.  Counts minutes from 0000 at midnight
    Blue_on_Time var word                   'stores the blue on time as a digit in minutes, eg 14:00hrs = 840
    Blue_off_Time var word                  'stores the blue off time as a digit in minutes, eg 14:00hrs = 840
    White_on_Time var word                  'stores the white on time as a digit in minutes, eg 14:00hrs = 840
    White_off_Time var word                 'stores the white off time as a digit in minutes, eg 14:00hrs = 840
    white_delay_in var byte                 'stores the white fade in pule in seconds
    blue_delay_in VAR byte                  'stores the blue fade in pule in seconds
    white_delay_out var byte                'stores the white fade out pule in seconds
    blue_delay_out VAR byte                 'stores the blue fade out pule in seconds
    W_Min           var byte                'Min Light value - Whites
    W_Max           var byte                'Max Light value - Whites
    B_Min           var byte                'Min Light value
    B_Max           var byte                'Max Light value
    Old_B_Max var byte
    Old_W_Max var byte
    W_PWM           var word                'PWM Variables where the current output values are stored - Whites
    B_PWM           var word                'PWM Variables where the current output values are stored - Royal Blues
    old_ss_blue     var byte                'records the previous second in blue fade in
    old_ss_white    var byte                'records the previous second in white fade in
    option          var byte                'menu option, used to choose which menu option is required
    Viv             var byte                'used to select the channel the menu selection applies to
    maxbright       var byte                'general variable used to set the max brighness for each channel in menu option
    fn              var byte                'general variable to switch between channels in menu options
    Hours           var byte                'used in menu options to set hours for each channel
    Minutes         var byte                'used in menu options to set minutes for each channel
    light           var byte
    Sumplighton     Var word                'counter variable for sump on time
    Sumplightoff    Var Word                'counter vairable for sump off time
    Sump_light      Var PORTA.4             'sump light pin
    sumponHR        VAR byte                'sump light on Hour
    sumponMN        var byte                'sump light on Minutes
    sumpoffHR       var byte                'sump light off Hours
    sumpoffMN       var byte                'sump light off Minutes
    daycount        var byte
    TimeH           var byte                'variable to store Hours
    TimeM           var byte                'variable to store Minutes
    SS              VAR Byte                'variable to store Seconds
    RTCsec          var byte                'RTC Seconds
    RTCMin          var byte		        'RTC Minutes
    RTCHour         var byte	            'RTC Hours
    SetMN           var byte		        'Used to set time Minutes
    SetHR           var byte	            'Used to set time Hours
    SetSS           var byte                'Used to set time Seconds
    SCLpin          var PORTC.3             'RTC pin - clk
    SDApin          var PORTC.4             'RTC pin - data
    CounterA        var byte	            'General purpose Variable
    CounterB        var byte	            'General purpose Variable
    CounterC        var byte	            'General purpose Variable
    CounterD        var byte	            'General purpose Variable
    FlashStar       VAR BIT
    Blue_Day_Cycle      var word            'Store for which part of the blue day cycle we are in
    White_Day_Cycle     var word            'Store for which part of the white day cycle we are in
    DAWN    con     0                       'Constants for the current running mode cycle for the lights
    DAY     con     1
    DUSK    con     2
    NIGHT   con     3
    ;Initialization
    LCDOUT $FE,1:FLAGS=0:PAUSE 250:LCDOUT $FE,1:PAUSE 250 ' Initialize LCD
    LCDOUT  $FE,1
    lcdout  $FE,$C0,"   Firmware v1.07   "
    pause   2000                            'wait 2 seconds so they can see it
    lcdout  $FE,1                           'Clear the screen
    Gosub read_eprom                        'read in presets for fade in durations and brighness
    blue_delay_in = (((fadesetHR[0]*60)+fadesetMN[0])*60)/255   'takes hours and minutes, converts to minutes, then converts to seconds
    white_delay_in = (((fadesetHR[1]/60)+fadesetMN[1])*60)/255  'takes hours and minutes, converts to minutes, then converts to seconds
    blue_delay_out = (((fadeoutHR[0]/60)+fadeoutMN[0])*60)/255  'takes hours and minutes, converts to minutes, then converts to seconds
    white_delay_out = (((fadeoutHR[1]/60)+fadeoutMN[1])*60)/255 'takes hours and minutes, converts to minutes, then converts to seconds
    Option = 1                              'sets the menu option default as 1 (set time)
    daycount=0                              'used in sumplight routine to check if gone passed midnight
    Sumplightoff =1439
    Sumplighton  =1439                      'sumplight - values used to match counter1 for on off times
    setHR = 13                              'initial time following programming or re-boot if RTC not battery backed up
    setMN = 59
    'convert initial time to BDC and write it to the DS1307
    CounterA=SetMN
    Gosub ConvertBCD
    RTCMin=CounterB
    CounterA=SetHR
    Gosub ConvertBCD
    RTCHour=CounterB
    I2Cwrite SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour]
    '************                     Main Program Loop              ***************
    If SetButton=0 then                     'if presed jump to the menu
    goto mainmenu
    ' check for manual override of the lights
    If H_butt = 0 then                      ' if pressed then change state of varible to 1
    Light=1
    If M_butt = 0 then                      ' if pressed then change state of varible back to 0
    Light=0
    'clock routine
    I2CREAD SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour]  ; read DS1307 chip
    timeH=(RTCHour>>4)                        'convert the BCD format of the hours register and store in variable timeH
    timeH=(timeH &$03)*10
    timeH=timeH+(RTCHour&$0F)
    timeM=(RTCMin>>4)                         'convert the BCD format of the mins register and store in variable timeM
    timeM=(timeM &$07)*10
    timeM=timeM+(RTCMin&$0F)
    ss=(RTCSec>>4)                            'convert the BCD format of the sec register and store in variable ss
    ss=(ss &$07)*10
    ss=ss+(RTCSec&$0F)
    Counter1 = (TimeH *60)+ TimeM             'take hours and multiply it by 60 then add odd minutes to get the total minutes into counter1
    LCDOut $FE,$D4+15,#TimeH DIG 1,#TimeH DIG 0,":",#TimeM DIG 1,#TimeM DIG 0
    ' check to see if the sump light should be on or off
    If daycount = 0 THEN                    ' by default daycount is 0
       If Counter1 => sumplighton Then      ' if the counter matched the sump light on time
         high sump_light                    ' then make the pin high and
         daycount = 1                       ' set the day count to 1
    IF daycount = 1 THEN                    ' if the daycount is 1 and
      If Counter1 = sumplightoff Then       ' conuter matches sump light off time
        low sump_light                      ' then make the pin low and
        daycount = 0                        ' reset daycount back to 0
    'Case Cycle logic
    If Counter1 < Blue_on_Time then
    Blue_day_cycle = NIGHT
    if counter1 > blue_on_time and Counter1 > blue_off_Time and B_PWM > B_Min then
    Blue_day_cycle = DUSK
    if counter1 => blue_on_time and Counter1 < blue_off_Time and B_PWM < B_MAX then
    Blue_day_cycle = DAWN
    If Counter1< White_on_Time then
    White_day_cycle = NIGHT
    if counter1 > white_on_time and Counter1 > white_off_Time and W_PWM > W_Min then
    White_day_cycle = DUSK
    if Counter1 => white_on_time  and Counter1 < white_off_Time and W_PWM < W_MAX then
    White_day_cycle = DAWN
    'BLUE daily cycle
    select case Blue_Day_Cycle
    case DAWN
    lcdout $FE,$80+15,"DAWN "
    if ss//blue_delay_in = 0 then
    if ss != old_ss_blue then
    B_PWM=B_PWM+1
    old_ss_blue=ss
    if B_PWM = b_max then
    Blue_Day_Cycle = DAY
    case DAY
    lcdout $FE,$80+15,"DAY  "
    if B_max < B_PWM then
    B_PWM=B_PWM - 1
    if counter1 =blue_off_time then
    CASE DUSK
    lcdout $FE,$80+15,"DUSK "
    if ss//blue_delay_out= 0 then
    B_PWM=B_PWM-1
    old_ss_blue=ss
    if B_PWM = B_MIN then
    Blue_Day_Cycle = NIGHT
    case NIGHT
    lcdout $FE,$80+15,"NIGHT"
    B_PWM=B_min
    end select
    'WHITE daily cycle
    select case White_Day_Cycle
    case DAWN
    lcdout $FE,$C0+15,"DAWN "
    if ss//white_delay_in= 0 then
    if ss != old_ss_white then
    W_PWM = W_PWM+1
    old_ss_white=ss
    if W_PWM = W_max then
    White_Day_Cycle = DAY
    case DAY
    lcdout $FE,$C0+15,"DAY  "
    if W_max < W_PWM then
    W_PWM=W_PWM - 1
    if counter1 =white_off_time then
    CASE DUSK
    lcdout $FE,$C0+15,"DUSK "
    if ss//white_delay_out= 0 then
    W_PWM=W_PWM-1
    old_ss_white=ss
    if W_PWM = W_min then
    White_Day_Cycle = NIGHT
    case NIGHT
    lcdout $FE,$C0+15,"NIGHT"
    W_PWM=W_min
    end select
    'tidy up the display for the current percentage to remove stray zero's
    If (B_PWM * 100)/255 = 100 then
    lcdout $FE,$80,"BL ",$FE,$80+3,dec3 (B_PWM *100)/255,"%"
    If (B_PWM * 100)/255 =0 or (B_PWM * 100)/255 <10 then
    lcdout $FE,$80,"BL ",$FE,$80+3,dec1 (B_PWM *100)/255,"% "
    if (B_PWM * 100)/255 >=10 and (B_PWM * 100)/255 <100 then
    lcdout $FE,$80,"BL ",$FE,$80+3,dec2 (B_PWM *100)/255,"%  "
    If (W_PWM*100)/255 >= 100 then
    lcdout $FE,$C0,"WT ",$FE,$C0+3,dec3 (W_PWM *100)/255,"%"
    If (W_PWM * 100)/255 <=0 or (W_PWM * 100)/255 <10 then
    lcdout $FE,$C0,"WT ",$FE,$C0+3,dec1 (W_PWM *100)/255,"% "
    if (W_PWM * 100)/255 >=10 AND (W_PWM * 100)/255 <100 then
    lcdout $FE,$C0,"WT ",$FE,$C0+3,dec2 (W_PWM *100)/255,"%  "
    'Get and display the temperature
        OWOUT DQ, 1, [$CC, $44]                 ' Start temperature conversion
        OWOUT DQ, 1, [$CC, $BE]                 ' Read the temperature
        OWIN DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE]
        temperature = temperature */ 1600
        lcdout $FE,$D4+0,"TEMP ",DEC(temperature / 100),$DF,"C"
    'generate bar graph on LCD
        ; syntax- BARgraph   Value, Row, Col, Width, Range, Style
       @         BARgraph  _B_PWM,   1,   8,    6,   255,  lines
       @         BARgraph  _W_PWM,   2,   8,    6,   255,  lines
    GOTO Main
    Darrels code seems to allow frequencies of 100hz which makes this ideal.... if it can be made to work
    I appreciate all your help....Hopefully Darrel can shed some light
    Oh and meant to add that it runs really slowly (displays the firmware splash screen for around fifteen seconds rather than the three or so
    The reason it runs slow is due to the interrupt driven PWM routines. You have a PWM frequency of 200Hz and a resolution of 256 steps, this results in an interrupt frequency of 51200Hz.
    According to Darrels page (if I'm on the right one) each "PWM-channel" needs 20 instructions - in your case 51200 * 20 * 2 = 2,048,000 instructions per second, just for running the 2 PWM channels. At 20MHz there's 5,000,000 instructions per second to play with which means that 40% of the processors time is spent running the PWM.
    You tell PBP that you're running at 20MHz but then the assembly interrupts silently eats away 40%.
    In this case each and every Hz you decrease the PWM frequency will give more time to the actual PBP program, if 100Hz is "all" you need then don't try running it at 200Hz. But again, it doesn't seem to be the timing per se that makes it NOT work since it using different ports for the PWM and I2C works.
    Oct 2009
    Thanks for the explanation...
    I think I'll go back to using port D for the outputs and revert back to the mulit_swpm file. Not ideal, as I'll have to modify the PCB, but at least it works without the delays or screwing up the clock etc. If I get chance I'll try this on the old 16F877A chip rather than an 18F to see if this issue is chip related...
    Oct 2009
    I've recorded the wave form when using the hardware PWM modules on the chip to explain the issue I'm getting.
    If you compare this to using the multi_swpm file and port D you notice there are loads of spikes in the HWPM signal and some harmonics ? - the amplitude is also a lot less (I had to increase the volume for the HWPM to get a similar trace)
    As I've said a couple of times now:
    You can not run the hardware PWM at a frequency below 1221Hz - it's not a bug in PBP and not a hardware issue with the PIC or the circuit, it's just the way it is.
    The reason is because TMR2, which is used for the PWM timebase is 8 bits wide and has a prescaler with a maximum ratio of 1:16. At 20MHz the timer ticks at 5MHz, so 5,000,000/256/16=1220.7Hz. If you try anything lower than that it will not work properly and I'm pretty sure that's what you're seeing when trying to run it at 200Hz.
    To prove or disprove, try it again at 1500Hz and see if the waveform looks better. I understand that it won't work in your particular application due to the LED drivers but it'll show that actual problem is that you're trying to run the PWM at a frequency (200Hz) which the module is incapable of producing.
  1. Multiple PWM pins
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 17th November 2013, 20:23
  2. Darrel's Multiple Software PWM
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 15th October 2013, 16:21
  3. Drive multiple LED with one PWM
    By microuser in forum General
    Last Post: - 27th September 2007, 14:26
  4. Multiple Pics to One serial port
    By Rleonard in forum Serial
    Last Post: - 18th January 2007, 19:30
  5. Multiple IR LEDs from 1 port using transistor
    By belpe123 in forum General
    Last Post: - 20th May 2005, 23:07
