MIBAM blinky on 16f628
Results 1 to 3 of 3
    Mar 2005
    CROATIA
    Default MIBAM blinky on 16f628
    Hi there,
    I was experimenting with mibam on 15 pins on 16f628 @20mhz
    it is working but a bit slow (blinky), is there any mibam option to use
    7 bit BAM to raise refresh, or it don't give any result ?
    128 (or even 64) steps would be absolutely enough....
    what is your opinion, and if is possible, how we can
    modify mibam code to obtain this ?
    regards.
    Default Re: MIBAM blinky on 16f628
    It should be fine with 15 LED's on a chip running @ 20Mhz.
    What does DEFINE BAM_INFO 1 show?
    Mar 2005
    CROATIA
    Hi, i have 143 hz, is not slow for static installation but we try to make crazy motorbike back light for my friend
    (direction, stop etc) and when is faded leds make (POV) trail in drive, i know is better using some hardware pwm driver
    but as we already put this, but we made only simulation for 15ch because don't have enough pins, now we remake it on
    16f1827 which can do internal 32mhz, (2 pin more without resonator) and ha 4 hwpwm, so this combination probably will be better
    I was wandering if leaving one bit out from mibam can alter refresh, or this does
    to many changes in code ?, if is not more than remark few line then forget, we will try some r-c filters on output.
    we only playing/experimenting with that, he had idea to fade lights at night, and make running paterns...
    as i said play/experimenting, and learning, because that we wandered how/if would mibam work with one or two bit less....
    i know maybe dummy, question, but could mibam work on external iex 74HC595 shift reg (or two) drived with hw MSSP ?? or too many variables
    as already have my PBP-Idol responded
    regards
  1. DT-INTs Blinky Light question
    By circuitpro in forum mel PIC BASIC Pro
    Last Post: - 5th February 2010, 04:29
  2. MIBAM on 16F628
    By idtat in forum mel PIC BASIC Pro
    Last Post: - 18th February 2009, 13:42
  3. Blinky not working with TOGGLE
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 09:45
  4. My first Blinky!
    By nomad in forum mel PIC BASIC Pro
    Last Post: - 25th September 2007, 18:29
  5. An other newby, an other blinky probem
    By Maniac in forum mel PIC BASIC Pro
    Last Post: - 23rd September 2005, 16:16
