STR \ Coun max len?
Results 1 to 5 of 5
    Sep 2009
    Default STR \ Coun max len?
    Is there way to make count for STR to be larger than 1 byte. As far as I can see in pbppic18.lib it uses only one byte for countdown. I can make 2 byte counter, but I can't find where is stored high byte of count.
    I need to receive 700 bytes in array...
    I'll try to solve it with FOR/NEXT...
    Default Re: STR \ Coun max len?
    Could you receive two blocks of 256 bytes and then one block of 188 bytes?
    Sep 2009
    No.
    Because I need one continues string. It work with FOR...
    Compiler passes only low byte of count to R4.Byte1(system var). It would be nice to have some warning when compiler do that.
    So it isn't just some change in lib files, it would require changes to compiler. Probably isn't worth doing that...
    But when using 18F parts that have over 3K of RAM, and compiler all ready support arrays longer 255 byte, it would be nice to use STR same way for all arrays, independent of their size...
    Receive 700 bytes into a single array using STR.
    MyArray   VAR BYTE[700]
    HSERIN [WAIT("!"), STR MyArray\200, STR MyArray(200)\200, _
                       STR MyArray(400)\200, STR MyArray(600)\100]
    Sep 2009
    Thanks, Darrel.
  1. STR ArrayVar question
    By MikeRant in forum mel PIC BASIC Pro
    Last Post: - 26th May 2011, 23:01
  2. HSERIN and STR - character encoding
    By boban in forum mel PIC BASIC Pro
    Last Post: - 13th August 2008, 18:36
  3. Help with STR ArrayVar\n\c with SerIn2
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 15th May 2006, 02:04
  4. Serin2 and STR Modifier
    By _Ian in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2005, 17:25
  5. STR function blues...
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 30th October 2004, 03:10
