How to use the 18F2420
Results 1 to 5 of 5
    BigWumpus, the 2431 was added in version 2.45.The 2410,2420,2455,2480 were added in version 2.46 so unless you have version 2.46 you need to upgrade.
    Hangover, Germany
    I see the problem...
    The next problem:
    Compiling for the PIC18 you must use the MPASM instead of the Assembler from MeLabs. So you have to use another syntax!
    And the MicroCode Studio doesn't jump to the the errors inside the Source.
    So I think of switching to the Proton, but No-one is able to talk about that product in this forum.
    It's not that you can't talk about Proton here which is really for MeLab's PICBasic, it's just that there is a better place to discuss Proton... go here... where the knowlegeable people that use Proton reside...
    http://www.picbasic.org/forum/
    Apr 2006
    Cool Which type of pic18 is suitable?
    Hi there,i am trying to migrate from PIC16F877 to some higher speed Microcontroller like PIC18F series i need 5 PWM channel or more and 10 bit ACD Resolution,USB compatible ,40 I/O pin or more basically i am using it to control motor and also some automation purposes.Can anyone recommend some of the robust PIC18F series?
  1. Tiny Bootloader 18F2420
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 31st March 2010, 17:32
  2. 18F2420, instant interrupts, and TMR0
    By dhickman in forum mel PIC BASIC Pro
    Last Post: - 11th March 2009, 18:33
  3. write_program_eeprom 18f2420
    By Blob in forum Off Topic
    Last Post: - 11th October 2006, 15:44
  4. PEEKCODE in the 18f2420
    By Dick M in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 16:34
