not sure if a simulator show this to be working for this chip by chance ?
Do this:
Then post source and compiled hex. You may not have to.Code:Whatever your minimal config and setup for PULSIN on two ports here, and make a pin that DOES work and a pin that DOES NOT work an input if PBP requires it for PULSIN. @ nop @ nop @ nop PULSIN on a pin that does work @ nop @ nop @ nop PULSIN on a pin that does not work 'pulsin PORTF.2,1,Leader @ nop @ nop @ nop
It's easy to at least tell if the bank switching is happening,
but maybe not the LCD configuration.
