yep thought it may have been the lcd option causing this , but i can read the ports directly so see if they are 1 or 0 also the lcd option is output segments , the ports are configured as inputs , both have analog options on them but i believe i have set this correctly for both ports
The only thought i have is that cos the ports F & G are not in the mem bank 0 , then pulsin does read the information correctly and not able to use them ?
but if some one has a chip that has ports that not use mem bank 0 - usually above port E , and pulsin works then that theory is shot , but be nice to know
hears the code relating to the tests and part of the chip config as it relates to port F and G
testing port F at the momentCode:'----------- 16F1947 - PIC chip Dephalt settings -------------------- OSCCON = $70 ' Select 32Mhz , internal clock ( 8Mhz when conf2 - PLLEN_OFF) ' Bit 7 0 = 4xPLL disabled 1= 4xPLL enables ( overrided by conf word 2 setting - PLLEN) ' bits6-3 - 1111 = 16Mhz , 1110 = 8MHz or 32Mhz ( depends on 4xPLL - conf word 2) 1101 = 4 MHz, 1100 = 2MHz 1011 = 1MHz ' bitS 0-1 - 00= Clock set by Conf word ,01 = Timer1 OSC , 1x = internal Osc Block ' WDTCON = %00000000 ' Bit 7,6 = 0 n/a , Bit 5-1 = watchdog timer period select , bit 0 = SWDTEN enable / disable for Watchdog timer bit ( WDTE) ' set watchdog timer for 1ms and enabled by SWDTEN bit being set ( mode selected with _WDTE setting in Config1) APFCON = %00000000 ' All Default - No change when using SPI use SDO1 = RC2 , bit6=0 CPSCON0 = $00 ' Capcitive Sensing Control Disable CPSCON1 = $00 ' Disable CSC - used with CPSCON0 CM1CON0 = $00 ' Disable / Clear comparator 1 CM1CON1 = $00 ' Used with CM1CON0 CM2CON0 = $00 ' Disable / Clear comparator 2 CM2CON1 = $00 ' Used with CM2CON0 CMOUT = $00 ' Disable Comparitors output register - used only if comparitor on SRCON0 = %00000000 ' Disable Latched Outputs SRCON1 = %00000000 ' Used with SRCON0 register DACCON0 = $00 ' Disable D/A DACCON1 = $00 ' Disable D/A - used with DACCON0 LCDCON = $00 ' Disable LCD module LCDPS = $00 ' Disable LCD module & LCD Phase Register LCDCST = $00 ' Resistor lader contrast control LCDREF = $00 ' Disable LCD voltage refernace control LCDSE0 = $00 ' LCD segment enable register LCDSE1 = $00 ' LCD segment enable register LCDSE2 = $00 ' LCD segment enable register LCDSE3 = $00 ' LCD segment enable register LCDSE4 = $00 ' LCD segment enable register LCDSE5 = $00 ' LCD segment enable register LCDRL = $00 ' LCD Ref ladder enable / disable OPTION_REG.7 = 1 ' Weak Pullups disabled 1 = globel disable 0 = globel enable ( set by each port - WPUB settings) OPTION_REG.6 = 0 ' Interupt on Falling Edge of INT pin 0= falling edge 1= rising edge OPTION_REG.5 = 0 ' TMR0 clock source - 1=T0clk pin 0=internal clock OPTION_REG.4 = 0 ' TMR0 0=L/H of TOCKI pin 1=H/L of TOCKI pin OPTION_REG.3 = 0 ' Use Prescaller for TMR0 0= Yes , 1 = No OPTION_REG.2 = 1 ' Timer0 prescaler Rate Select bits 2-0(set to 1:256) OPTION_REG.1 = 1 ' 000 = 1:2 , 001= 1:4 , 010 = 1:8 , 011 = 1:16 OPTION_REG.0 = 1 ' 100 = 1:32 , 101 = 1:64, 110 = 1:128 , 111 = 1:256 T1CON = %01110100 ' Timer 1 ,bit7-6 = TMR1 CLK source 00 = Instuction Clk(Fosc/4),01 =sys clk,10=ext clk,11=cap sense osc ' bit5-4 = TMR1 prescale 11= 1:8 ,bit3=0 LP off,bit2=1 no sync ext CLK ,bit1= 0 n/a,Bit0=0 Timer 1 on/off T1GCON = %00000000 ' Timer 1 Gate Control bit7 0= counts regardless of gate 1 = gates in use , bit6 gate active when 1= High ,0=low ' bit5 0= toggle mode diabled 1= enabled bit4 single pulse mode 1- en 0= dis, bit 2 -status bit,1-0 - gate source sel T2CON = %01110011 ' Timer 2 off + 1:15 postscale ,1:64 prescale ( bit 7 = x, bit6-3 1110 = 1:15 postscale, bit2=0 timer off ,bit1-0 = prescale 10 = 16 , 11= prescale 64 T4CON = %00000000 ' POSTSCALER 1/1,STOP,PRESCALER 1/1 T6CON = %00000000 ' POSTSCALER 1/1,STOP,PRESCALER 1/1 TMR0 = 0 ' Clear TMR0 MODULE REGISTER TMR1H = 0 ' CLEAR TMR1H MODULE REGISTER TMR1L = 0 ' CLEAR TMR1L MODULE REGISTER TMR2 = 0 ' CLEAR TMR2 MODULE REGISTER TMR4 = 0 ' CLEAR TMR4 MODULE REGISTER TMR6 = 0 ' CLEAR TMR6 MODULE REGISTER 'PR2 = 255 ' Timer 2 Preload value 'PR4 = 255 ' Timer 4 Preload value 'PR6 = 255 ' Timer 6 Preload value
currently Port G is setup for output ( except G.5 which is always input and config 1 " MCRLR is used for reset and not a digital input pin)Code:' ------- Setup port F Variables ---------- ANSELF = %00000000 ' Set Port F - Digital I/O , 0 = Digital 1 = Analog TRISF = %11111111 '( ports input)
Port G has 6 I/O only
but when confirming test with pulsin
TRISG = %00111111
test 1 - test pulsin with a clock source time period of 1ms high pulses applied on each portCode:' ------- Setup port G Variables ---------- ANSELG = %00000000 ' Set Port G - Digital I/O , 0 = Digital 1 = Analog TRISG = %00100000 ' setup Port G input=1,output=0 for I/O pins - portG.5 always input ( internal pullup) VPP/MCLR PORTG = %00100000 ' Clear Outputs
Code:DEFINE OSC 32 ' Timing reference for pause , pauseus commands DEFINE PULSIN_MAX 5600 ' Maximum counts( clock ticks) allowed before pulsin times out( 5600 ^ 1.25us = 7 ms) Main: pulsin PORTF.2,1,Leader if leader > 0 then write $A0 , Leader.highbyte ' debug only write $A1, Leader.Lowbyte 'debug goto main
Test 2 - read logic level of port and write something to show if it was a 1 or 0 to eeporm
Code:if PORTF.2 = 1 THEN LEADER = $1234 if PORTF.2 = 0 THEN LEADER = $5678 write $10,Leader.highbyte write $11,Leader.lowbyte
