OTHER SETTINGS that affect portF and Port G - are disabled
also tried just seeing if each pin on the PORT F and G was able to see the clock pulses presented to each input pin , and seems to see both 0 and 1 on all ports , so not a solder/ board issue ,
but any measurement using Pulsin or RCtime wont work ???
also ensured the ADCON0 is disabled during the test
yep this one has me stumped !!
    APFCON = %00000000	    ' All Default - No change when using SPI  use SDO1 = RC2 , bit6=0
    CPSCON0 = $00           ' Capcitive Sensing Control Disable
    CPSCON1 = $00           ' Disable CSC - used with CPSCON0
    CM1CON0 = $00 	        ' Disable / Clear comparator 1
    CM1CON1 = $00 	        ' Used with CM1CON0
    CM2CON0 = $00 	        ' Disable / Clear comparator 2
    CM2CON1 = $00 	        ' Used with CM2CON0
    CMOUT   = $00           ' Disable Comparitors output register - used only if comparitor on
    SRCON0 = %00000000      ' Disable Latched Outputs
    SRCON1 = %00000000      ' Used with SRCON0 register
    DACCON0 = $00           ' Disable D/A
    DACCON1 = $00           ' Disable D/A - used with DACCON0
    LCDCON = $00            ' Disable LCD module
    LCDPS  = $00            ' Disable LCD module  &  LCD Phase Register
    LCDCST = $00            ' Resistor lader contrast control
    LCDREF = $00            ' Disable LCD voltage refernace control
    LCDSE0 = $00            ' LCD segment enable register
    LCDSE1 = $00            ' LCD segment enable register
    LCDSE2 = $00            ' LCD segment enable register
    LCDSE3 = $00            ' LCD segment enable register
    LCDSE4 = $00            ' LCD segment enable register
    LCDSE5 = $00            ' LCD segment enable register
    LCDRL  = $00            ' LCD Ref ladder enable / disable
