my project Capacitive Sensing LED dimmer 12F1822 via PWM
Results 1 to 40 of 43
    Oct 2009
    Utah, USA
    Default Re: my project Capacitive Sensing LED dimmer 12F1822 via PWM
    If you look at the datasheet for the 12f1822 you will see that only pins A.0, A.1, A.2 and A.4 have cap sense capability.
    You will have to work with those pins.
    Also, as Charlie and others have pointed out, I would not do the Zener regulator. It is inefficient and does not allow one to draw more or less current as your circuit might demand, at least not efficiently.
    The Zener regulator idea was a bad one... especially with the LDO regulators available for about the same cost and parts count.
    Dwight
    Oct 2013
    My mistake,I mean portA.4 but wrong I write on post.
    Oct 2009
    Utah, USA
    Have you been able to get the circuit and/or code working as I posted above?
    Once you get it working as posted then you can work on getting other features and customize it as you want.
    Right now each time you touch the cap sense pad it changes the LED brightness using PWM
    Dwight
    Oct 2013
    today I receive a free samples from Microchip and I got a big surprise.My EasyPIC5 development board can not program PIC12f1288 so I can not to try your code.
    I have another PIC16f724 with capacitance sensing module But I dont have a working example for him.I try to adjust your code to PIC16f724 but I have a error while compiling.
    ASM ERROR symbol not previously defined (TMR1) (0) error 113
    When I compiling your code for 12F1288 I dont have this error.
  1. 16F726 Capacitive sensing module
    Last Post: - 15th May 2014, 19:40
  2. Need help setting up Capacitive Sense 12F1822
    By Heckler in forum mel PIC BASIC Pro
    Last Post: - 29th November 2013, 21:10
  3. Replies: 1
    Last Post: - 6th August 2012, 10:57
  4. Capacitive sensing module on 16f1936
    By grahamg in forum mel PIC BASIC Pro
    Last Post: - 25th April 2010, 14:17
  5. mTouch capacitive sensing
    By jrprogrammer in forum mel PIC BASIC Pro
    Last Post: - 1st November 2008, 22:54
