my project Capacitive Sensing LED dimmer 12F1822 via PWM
Results 1 to 40 of 43
    Sep 2009
    Default Re: my project Capacitive Sensing LED dimmer 12F1822 via PWM
    I would use LDO with low Iq, eg. tps709135
    And put pic in sleep, wake up with timer interrupt, do things, back to sleep...
    This way you can get average current very low, under 100uA.
    Oct 2009
    Utah, USA
    Wow, I didn't know they made voltage regulators with that low of idle current.
    My intention was to be able to leave the ckt connected to a, say 7 Ah, gel cell battery for at least a few weeks.
    I will probably add to the circuit board a jumper or small switch to completely disconnect the ckt for storage. Even 1 ma will use up 8.76 Ah in a year. Probably not much more than the self discharge of the batt, though.
    For a hobbyist though the junk box is your friend. That regulator is a bit esoteric and the shipping cost would drive up the cost for just a few items.
    If you study Zener regulator ckts they are somewhat inneficient if your current needs vary by much. This ckt would get below 2 volt if the current draw gets over 1ma with a 12V source. Since my ckt pulls a bit less than that I am OK. Actually now that I look at it I may want to lower the 10K resistor to say a 5K or so. It's all just experimentation at this point.
    If one wants to be able to draw more current for the other PIC pin outputs then it quickly becomes necessary to use a lower value resistor.
    I'm sure a good electronics engineer could shred this idea for any kind of commercial application.
    Mostly I was determined to get the Cap Sense working and be able to evaluate its suitability for other applications.
    Sometimes I just enjoy the challenge of figuring out these Little PICS and what they are capable of. They truly are amazing what is in these little packages for such a few dollars.
    For example the APFCON register. It allows you to move the function of some of the PIC peripherals from one pin to another if needed!! (which I did need to do with the PWM from A.2 to A.5)
    Dwight
    Oct 2009
    Utah, USA
    Ok Demon,
    You got me thinking and as I did some more measuring I found that, with the 10K R, I had only 2 volts to the PIC. Which is ok but mabie a bit low. So I switched out the resistor to a 4.7 K and now I have 3.95V to the PIC and the current draw is 1.7ma (0.0017Amps)
    I used one of these... http://www.eevblog.com/projects/ucurrent/
    to measure the current
    The zener is probably still not working too hard to control the voltage yet (not sure how sharp the zener voltage point is)
    Any way I just wanted a simple way to power this ckt from the 12 to 15 Volt source battery.
    Dwight
    Oct 2009
    Utah, USA
    If anybody is interested I have modified the CODE so that the light turns off after 30 minutes.
    not too hard to do, but I'd be glad to post it.
    Dwight
    I'd use Darrel's interrupts and check the Minutes. Is that the easy way out?
    Is it more efficient to use another method?
    just counting the " PAUSE 100 " loops allows +/- 8000 seconds or around 2 hours ...
    also allows to clear counter if action detected ...
    not a good idea ???
    Quote Originally Posted by Acetronics2 View Post
    not a good idea ???
    They're all good ideas as long as the house doesn't catch on fire.
    Oct 2009
    Utah, USA
    @Acetronics2... great minds must think alike
    That's pretty much what I did.
    @Charlie... my design is specifically designed to run on battery power. The PIC current drain should not change by much. Unless one starts trying to supply current via other pins. That is why I would limit other pin outs to supplying ground when active. (I think this is correct, but I am open for debate)
    My intent was to specifically create a Camping/Emergency light that could be dimmed for maximum battery life. My crude measurements with the PWM output is that on low the current is around 1, 6, 25, 50, 100 milliamps respectivily with each of the 5 steps.
    I really was not going to do much, if anything, else with the other pins.
    In this case I think the current draw of the PIC should be quite stable and very low.
    If one starts doing other things with the other pins then all bets are off with the zener/resistor supply.
    And, hey, since I am a hobbiest it might be fun to let the smoke out of a PIC to learn a little. See how much abuse one of these little jems can take and keep on ticking. (evil grin)
    Here is my code that turns the light off after approx 30 min.
    I may modify it to blink the led to warn that the 30 min is about to expire so the user can hit the touch sense pad again to go another 30. The sky is the limit and that is the beauty (as you all surely know) of software control. Can we all say "feature creep".
    PS. As I look at the code I wonder if some are the pause statements sprinkled around are really necessay.
    One thing I do notice is that the touch sense requires a definate quick tap to be detected. I think this is because the calculation inside the interrupt routine demands a change of approx 20% from the last INT to be counted as a "touch". One can have all sorts of fun playing with some of those numbers and seeing how it changes the Capacitive sensitivity.
    '*  Author  : Dwight and others                                 *
    '*  Notice  : Copyright (c) 2013 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 11/29/2013                                        *
    '*  Notes   :   PIC12F1822                                                *
      __CONFIG _CONFIG1, _FCMEN_OFF & _FOSC_INTOSC & _WDTE_SWDTEN & _MCLRE_OFF & _CP_OFF & _IESO_OFF & _BOREN_OFF & _PWRTE_OFF
      __CONFIG _CONFIG2, _LVP_OFF
    DEFINE  OSC 8                'tell picbasic what speed the oscillator is
    INCLUDE "DT_INTS-14.bas"     '
    OSCCON = %01110010
                            '0 = 4x PLL is disabled
                            ' 1110 = 8 MHz
                            '     0 = unused
                            '      1X = Internal oscillator
    ANSELA = %00000100        'make port A.2 is analog
    TRISA  = %00000100        'port A.2 is input
    WPUA   = %00000000        'turn off weak pull ups
    APFCON = %00000001        'Alternate Pin Function Control Reg (default %00000000)
                              'move CCP to PortA.5 (for PWM output)
    OPTION_REG = %10000111
                            '1 = All weak pull-ups are disabled (except MCLR, if it is enabled)
                            ' 0 = Interrupt on falling edge of RB0/INT pin
                            '  0 = Timer0 clock is internal cycle clock (Fosc/4)
                            '   0 = Increment on low-to-high transition on RA4/T0CKI pin
                            '    0 = Prescaler is assigned to the Timer0 module
                            '     111 = 1:256 Timer0 prescaler rate
    T1CON = %11000001       'enable timer 1 (bit 0) & source the clock from the CPS module (bit 6 & 7 =11
    CPSCON0 = %10001100     'set the CPS module highest frequency availabe (for vcc mode) + timer0 clock sourced from CPS module. (BIT 1)
                            '1 = CPS module is enabled
                            ' 0 = CPS module is in the low range. Internal oscillator voltage references are used.
                            '  00 = unused
                            '    11 = Oscillator is in High Range. Charge/Discharge Current is nominally 18 µA
                            '      0 = Capacitive Sensing Oscillator Status bit (only readable)
                            '       0 = Timer0 clock source is controlled by the core/Timer0 module and is FOSC/4
    CPSCON1 = %00000010        '0010 = channel 2, (CPS2)
    CM1CON0 = 0   ' COMPARATOR OFF
    CM1CON1 = 0   ' COMPARATOR OFF
    CPS2_PRESENT    var WORD
    CPS2_THRESHOLD  var WORD
    CPS2_LAST       var WORD
    '       Software variables
    Duty    VAR WORD
    stepp   var byte
    AutoOFF var word
    ' ----------------[ I/O Definitions ]-----------------------------------
    FET VAR PORTA.5  ' PWM output to control the FET switch
    '       Software/Hardware initialisation
    PAUSE 100                           ' OSC settle delay
    Autooff = 0
    Duty = 0
    stepp = 5
    hpwm 1,255,250                     ' Start with Light full ON
            INT_Handler   TMR0_INT,  _Timer0_Int,   pbp,  yes
    TMR0 = 0                  'clear  TIMER0
    @ INT_ENABLE  TMR0_INT    'enable timer0 interrupts
    '------------------------------< Main program >-------------------------
    if autooff = 0 then skipoff
    if stepp = 0 then autooff = 0
    autooff = autooff + 1
    if autooff = 600 then    '(20=1 minute, 600=30 minutes) X delay till AutoOFF
        autooff = 0
        hpwm 1,0,250  'turn LED off after X delay
        stepp = 0
    SkipOFF:
    pause 1000   ' not a whole lot going on here
    Timer0_Int:
    @ INT_DISABLE  TMR0_INT   ' stop timer0 interrupts while we're in here
    pause 25
    CPS2_PRESENT = TMR1                                ' take a snapshot of Timer1's present count.
    CPS2_THRESHOLD = CPS2_LAST - ((CPS2_LAST/10)*2)    ' this sets the 'trigger' up for a 20% diversion (finger press)
    CPS2_LAST = CPS2_PRESENT                           ' store away the present timer0count for the next time we come into the interrupt routine
    if cps2_present < cps2_threshold then
        autooff = 1
        stepp = stepp +1
        if stepp>6 then stepp=0            ' check for rollover
        lookup stepp, [0,1,16,64,128,255,255],duty  'choose level, 5 levels plus OFF
        if stepp=6 then
            hpwm 1,0,1000    'off              ' arrive here when brightness is MAX
            pause 100                          '    So blink to let user know.
            hpwm 1,255,1000  'on
            hpwm 1,0,1000    'off
            hpwm 1,255,1000  'on              ' blink to show that you are at the highest level
        hpwm 1,duty,250                    ' else set new level                       ' button pressed so increment stepp
    pause 50
    TMR0 = 0                  ' clear TIMER0
    TMR1 = 0                  ' clear TIMER1
    @ INT_ENABLE  TMR0_INT    ' re-enable timer0 interrupt
    @ INT_RETURN
    Dwight
    C'mon Dwight, Post it, you know you want to. Somebody will see it and learn something from it, possibly me.
  1. 16F726 Capacitive sensing module
    Last Post: - 15th May 2014, 19:40
  2. Need help setting up Capacitive Sense 12F1822
    By Heckler in forum mel PIC BASIC Pro
    Last Post: - 29th November 2013, 21:10
  3. Replies: 1
    Last Post: - 6th August 2012, 10:57
  4. Capacitive sensing module on 16f1936
    By grahamg in forum mel PIC BASIC Pro
    Last Post: - 25th April 2010, 14:17
  5. mTouch capacitive sensing
    By jrprogrammer in forum mel PIC BASIC Pro
    Last Post: - 1st November 2008, 22:54
