my project Capacitive Sensing LED dimmer 12F1822 via PWM
Results 1 to 40 of 43
    Default Re: my project Capacitive Sensing LED dimmer 12F1822 via PWM
    One thing that did occur to me (during the night ) is that this type of power supply would limit the PIC's ability to provide a "high" output with any amount of current. So if you want to use those pins for something else you would want the active state to be a LOW or ground, or change the value of the 10K resistor to a lower value.
    What if you just used VDD (pin 1) as your source, couldn't you then do as you please with that "regulated" 5V?
    Edit: ok, I see where you're going. Even using a transistor on the pin, you're still limitted by what can pass through the resistor.
    What if you use a higher wattage resistor?
    Glue a heatsink on it.
    Sep 2009
    I would use LDO with low Iq, eg. tps709135
    And put pic in sleep, wake up with timer interrupt, do things, back to sleep...
    This way you can get average current very low, under 100uA.
    Oct 2009
    Utah, USA
    Wow, I didn't know they made voltage regulators with that low of idle current.
    My intention was to be able to leave the ckt connected to a, say 7 Ah, gel cell battery for at least a few weeks.
    I will probably add to the circuit board a jumper or small switch to completely disconnect the ckt for storage. Even 1 ma will use up 8.76 Ah in a year. Probably not much more than the self discharge of the batt, though.
    For a hobbyist though the junk box is your friend. That regulator is a bit esoteric and the shipping cost would drive up the cost for just a few items.
    If you study Zener regulator ckts they are somewhat inneficient if your current needs vary by much. This ckt would get below 2 volt if the current draw gets over 1ma with a 12V source. Since my ckt pulls a bit less than that I am OK. Actually now that I look at it I may want to lower the 10K resistor to say a 5K or so. It's all just experimentation at this point.
    If one wants to be able to draw more current for the other PIC pin outputs then it quickly becomes necessary to use a lower value resistor.
    I'm sure a good electronics engineer could shred this idea for any kind of commercial application.
    Mostly I was determined to get the Cap Sense working and be able to evaluate its suitability for other applications.
    Sometimes I just enjoy the challenge of figuring out these Little PICS and what they are capable of. They truly are amazing what is in these little packages for such a few dollars.
    For example the APFCON register. It allows you to move the function of some of the PIC peripherals from one pin to another if needed!! (which I did need to do with the PWM from A.2 to A.5)
    Dwight
    Oct 2009
    Utah, USA
    Ok Demon,
    You got me thinking and as I did some more measuring I found that, with the 10K R, I had only 2 volts to the PIC. Which is ok but mabie a bit low. So I switched out the resistor to a 4.7 K and now I have 3.95V to the PIC and the current draw is 1.7ma (0.0017Amps)
    I used one of these... http://www.eevblog.com/projects/ucurrent/
    to measure the current
    The zener is probably still not working too hard to control the voltage yet (not sure how sharp the zener voltage point is)
    Any way I just wanted a simple way to power this ckt from the 12 to 15 Volt source battery.
    Dwight
    Oct 2009
    Utah, USA
    If anybody is interested I have modified the CODE so that the light turns off after 30 minutes.
    not too hard to do, but I'd be glad to post it.
    Dwight
    I'd use Darrel's interrupts and check the Minutes. Is that the easy way out?
    Is it more efficient to use another method?
    just counting the " PAUSE 100 " loops allows +/- 8000 seconds or around 2 hours ...
    also allows to clear counter if action detected ...
    not a good idea ???
    Quote Originally Posted by Acetronics2 View Post
    not a good idea ???
    They're all good ideas as long as the house doesn't catch on fire.
    C'mon Dwight, Post it, you know you want to. Somebody will see it and learn something from it, possibly me.
  1. 16F726 Capacitive sensing module
    Last Post: - 15th May 2014, 19:40
  2. Need help setting up Capacitive Sense 12F1822
    By Heckler in forum mel PIC BASIC Pro
    Last Post: - 29th November 2013, 21:10
  3. Replies: 1
    Last Post: - 6th August 2012, 10:57
  4. Capacitive sensing module on 16f1936
    By grahamg in forum mel PIC BASIC Pro
    Last Post: - 25th April 2010, 14:17
  5. mTouch capacitive sensing
    By jrprogrammer in forum mel PIC BASIC Pro
    Last Post: - 1st November 2008, 22:54
