having a Very very quick look at the probe resistance table
http://www.micropik.com/PDF/pt100.pdf
it seem to move between 18R and 390R representing temps - -200deg C to 850Deg C.
You did not say what the pic voltage was , but assuming it at 5v i would connect the one side of the probe to the 5v and then to a resistor to ground and connect the joined point o the AN0 anaolog port
Calculating the resistor to ground using the voltage divider calculator
http://www.calculatoredge.com/electr...e%20divide.htm
i would start by using 390R 1% resistor , with the calculated values of 5v in , probe resistance range of Ra = 18R - 390R and the Rb being 390 this gives the voltage to the AD a range of 4.75V - 2.5v
i would setup the voltage reference on the pic to be VDD and measure the AD input ,
referring again to the probe table , its about 4R = 10Deg change , this calclulates to about 0.04v per 10 degrees using the above values , so depending on how accurate the probe is each 0.01v = 2.5degc change
setup a sample loop etc and average the reading
, have fun
cheers
Sheldon
it requires a connection of probe to voltage divider connected to one of the analog ports ,
