PT100 with temp
Results 1 to 6 of 6
Thread: PT100 with temp
    Nov 2007
    sri lanka
    Default PT100 with temp
    Dear all
    i want to interface (RTD)PT100 pic 16f877a .
    Feb 2012
    PERTH AUSTRALIA
    Default Re: PT100 with temp
    having a Very very quick look at the probe resistance table
    http://www.micropik.com/PDF/pt100.pdf
    it seem to move between 18R and 390R representing temps - -200deg C to 850Deg C.
    You did not say what the pic voltage was , but assuming it at 5v i would connect the one side of the probe to the 5v and then to a resistor to ground and connect the joined point o the AN0 anaolog port
    Calculating the resistor to ground using the voltage divider calculator
    http://www.calculatoredge.com/electr...e%20divide.htm
    i would start by using 390R 1% resistor , with the calculated values of 5v in , probe resistance range of Ra = 18R - 390R and the Rb being 390 this gives the voltage to the AD a range of 4.75V - 2.5v
    i would setup the voltage reference on the pic to be VDD and measure the AD input ,
    referring again to the probe table , its about 4R = 10Deg change , this calclulates to about 0.04v per 10 degrees using the above values , so depending on how accurate the probe is each 0.01v = 2.5degc change
    setup a sample loop etc and average the reading
    , have fun
    cheers
    Sheldon
    it requires a connection of probe to voltage divider connected to one of the analog ports ,
    Nov 2007
    sri lanka
    can u give me another solution.
    Feb 2012
    PERTH AUSTRALIA
    no its the only way i know how to go about it
    May 2008
    Italy
    http://ww1.microchip.com/downloads/e...Doc/01146B.pdf
    Read this documento, tip 13.1 and tip 13.2 seem a good solution to your application.
    Cheers
    Al.
  1. TMP05 Temp Sensor
    By RichG in forum mel PIC BASIC Pro
    Last Post: - 8th February 2009, 04:33
  2. TCN75 Temp Sensor
    By Frozen001 in forum mel PIC BASIC Pro
    Last Post: - 22nd September 2008, 21:37
  3. LM35DZ + Temp
    Last Post: - 5th March 2007, 08:05
  4. PT100 to SHT75
    By sour in forum mel PIC BASIC Pro
    Last Post: - 26th June 2006, 13:59
  5. Temp. Indicator.
    By PIC Coder in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 07:10
