Port indexing & PWM for LED fade
Results 1 to 10 of 10
    Alabama,USA
    Default Port indexing & PWM for LED fade
    Greatings! I have stated a new project working with PWM and fading LEDs. All is going well until I tried to combine two simple test routines. The first two routines work fine. When I tried to use port indexing with PWM it failed. Can anyone point out my error or does the PWM command have limitations on pin discriptions? Manual says it can be a variable or pin discription, e.g. PortB.0 Is there another way to do this?
    PIC16f886, PBP 2.6, using LAB X2 board.
    ;Cycle through PortB to fade ON then fade OFF eight LEDs in sequence.
    Symbol Port_Pin=PortB
        Avar    var byte
        Duty    var byte
        Cycle   var byte
    ;more stuff in here
    ;--[ LED fade ON and fade OFF   ]---------  works fine!
    FadeTest:
        cycle=4    ;cycle is number of cycles of pulse
        for Duty=0 to 100 step 1
            pwm led1,Duty,cycle
            next Duty
         cycle=1    ;cycle is number of cycles of pulse
         for Duty=100 to 0 step -2
            pwm led1,Duty,cycle
            next Duty
            low led1     ;end of routine
        goto FadeTest
    ;--[  PortB indexing LEDs       ]--------------  works fine!
    IndexTest:
        for Avar=0 to 7
           Port_Pin.0[Avar]=1
           pause 250
           Port_Pin.0[Avar]=0
           pause 250
        next
        goto IndexTest
    ;--[  FireFlies routine         ]-------------------  FAILED
    FireFlies:
        for Avar=0 to 7
            cycle=4
            for Duty=0 to 220 step 1
                pwm Port_Pin.0[Avar],Duty,cycle
                next Duty
            cycle=1
            for Duty=220 to 0 step -2
                next Duty
                low Port_Pin.0[Avar]     ;end of routine
        Next Avar
            goto FireFlies
    Comments please, Thanks.
    Wayne
    Aug 2003
    Default Re: Port indexing & PWM for LED fade
    Looks good to me if the addressing works with PWM.
    What happens if you only try to PWM a single LED when you address it that way.. same thing?
    I've read about the trick to address pins, what if you knock them into a declared array first,
    and then aliased each one, I wonder what that would do.
    pins[8] var byte
    portb.0 var pins[0]
    portb.1 var pins[1]
    portb.2 var pins[2]…
    Then cycle "pins" in the PWN command
    for selected = 0 to 7
    pins[selected] = value
    next selected
    Aug 2003
    but my comment is, software PWM command (not HPWM) is a dead end.
    How about starting with a constant loop that counts from zero to something,
    or a hardware counter, then look at that counter each cycle of your program,
    and determining which LEDs to turn on or off based on their own preset on/off counters.
    Then you can vary the counters, and you're not limited to a single simultaneous PWM channel.
    Alabama,USA
    Art, Thanks for your reply. PWM with a single LED or port (LED1 var PortB.1) or single port (PortB.1) will work with PWM however I have been unable to get indexing to work with the PWM in any shape, form, or fashion. Some LED will light up but will not be the one you addressed. I think the problem must be within the PWM command structure. It will not recognize the indexing as a port location. I tried several versions of your suggestion of array declaration, no luck. I think indexing in some form should work but I have not figured it out yet. I have the routine working with Select Case approach but an indexing method would reduce the code considerably. Work continues…
    from the book :- pwm pin,duty,cycle [ it says pin can be a constant or var from 0 to 15] whwre portb.0 = 0
    therefore this may work , I have not tested it
    for Avar=0 to 7
    cycle=4
    pwm Avar,Duty,cycle
    next Duty
    cycle=1
    pwm Avar,Duty,cycle
    next Duty
    low Avar ;end of routine
    Alabama,USA
    Richard, it worked, Thanks, although it raises as many questions as it answers.
    This works
            for Avar= 0 to 7
                    pwm Avar,Duty,cycle
                    next Duty
                    cycle=2    ;cycle is number of cycles of pulse
                    pwm Avar,Duty,cycle
                    next Duty
                    low Avar
            next Avar
    This works, on PortB, why? This should work on PortA. PortB, I tought, would be 8-15.
    Yes I had used ‘Symbol Port_Pin=PortB’ which would set PortB to 0-7 but now I’m not using Port_Pin in the routine. I remember there is a file somewhere that sets the port numbers but I can ‘t remember what or where it is. I may have changed the default numbering over the years. Oh well, it works and now and I’m happy. I’m surprised I had not seen an example for PWM that used this method to cycle through LEDs. Too easy! thank you both for your input!
    ; 16F886
    @ DEVICE INTRC_OSC,MCLR_ON,BOD_OFF,WDT_OFF,LVP_OFF
    define  osc 8
    ;------[ Set Hardware ]------------------------------------------------------
        OSCCON=$70    '$70=8MHz, $60=4MHz
        ANSEL=$00
        ANSELH=$0
        ADCON0=$00
        CM1CON0=0
        CM2CON0=0
        OPTION_REG=0    ; INTOC RB0 set to interrupt on falling edge
    	PORTA=%00000000
    	PORTB=%00000000
    	PORTC=%00000000     ' RAC6&7 set with Hserout command
    	TRISA=%00000011      ' PORTA RA0 & RA1 input all other output
    	TRISB=%00000000      ' PORTB all set to Onput
                  TRISC=%00000000      ' PortC     RC7&RC6 for hserout
    ;--[ VARIBLES, CONSTATNS ]-------------------------------------------------
    ;  Symbol Port_Pin=PortB   ; To define PortB port numbers start at RB.0
        Avar    var byte
        Duty    var byte
        Cycle   var byte
    ;--[ Main Program ]-------------------------------------------------------------
    Start:
        gosub FadeTest
    ;--[ Routine for fade on and fade off LEDs]------------------------------------
    FadeTest:
            for avar = 0 to 7
                for Duty= 0 to 220 step 1
                    pwm Avar,Duty,cycle
                    next Duty
                for Duty= 220 to 0 step -2
                    pwm Avar,Duty,cycle
                    next Duty
                    low Avar
            next Avar
    Hi All,
    I tried this just the way it's published to no avail, but did manage to make it work after tinkering a bit. I used a PIC Demo board featuring a PIC16F690 and the 4 LEDs on Port C as follows:
        __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_ON & _WDT_ON
    TRISA = 0
    TRISB = 0
    TRISC = 0
        ANSEL=$00
        ANSELH=$0
        ADCON0=$00
        CM1CON0=0
        CM2CON0=0
    	PORTA=%00000000
    	PORTB=%00000000
        Avar    var byte
        Duty    var byte
        Cycle   var byte
    Start:
        gosub FadeTest
    goto start
    FadeTest:
            for avar = 8 to 11
            PortC = avar << 2 &%00000001 ;& OP damps a leading on signal
                    pwm Avar,Duty,cycle
                    next Duty
                    cycle=3    ;cycle is number of cycles of pulse
                    pwm Avar,Duty,cycle
                    next Duty
            next Avar
             Avar = 8
    a quick read through the old pb2.6c book (page 30 in my edition) indicates the pin number is a hangover from the old basic stamp
    pin chips 0-7 8-15
    8 gpio
    14 porta portc
    18 portb porta
    28 portb portc
    remember that if you can
    Last edited by richard; - 2nd December 2013 at 22:07. Reason: editor eats white space
    Alabama,USA
    Yep! The manual says a constant of 0 -15. It just didn’t say that it starts on PortB.0 and continues into PortC.0 and then it confuses things by talking about PortA.0. the old basic stamp thing is just fine with me. No indexing needed, no fancy port descriptions, just a constants or variables of 0 – 15. Easy to cycle through or set up for Random enables. Why do I always complicate things! thanks guys for your comments.
    Wayne
    Just a comment on logic:
    Start:
        gosub FadeTest
        goto Start   <---- missing
  1. Help with LED driver fade on/off
    By dfort in forum mel PIC BASIC Pro
    Last Post: - 25th July 2009, 01:39
  2. PWM and fade effect
    Last Post: - 10th July 2009, 11:58
  3. Port Indexing
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 25th September 2006, 13:33
  4. LED fade without PWM command
    By Nick in forum mel PIC BASIC
    Last Post: - 29th June 2005, 21:56
  5. Fade out an LED using PWM?
    By RossW in forum mel PIC BASIC Pro
    Last Post: - 6th August 2004, 20:59
