Port indexing & PWM for LED fade
Results 1 to 10 of 10
Threaded View
  1. #2
    Aug 2003
    Default Re: Port indexing & PWM for LED fade
    Looks good to me if the addressing works with PWM.
    What happens if you only try to PWM a single LED when you address it that way.. same thing?
    I've read about the trick to address pins, what if you knock them into a declared array first,
    and then aliased each one, I wonder what that would do.
    pins[8] var byte
    portb.0 var pins[0]
    portb.1 var pins[1]
    portb.2 var pins[2]…
    Then cycle "pins" in the PWN command
    for selected = 0 to 7
    pins[selected] = value
    next selected
  1. Help with LED driver fade on/off
    By dfort in forum mel PIC BASIC Pro
    Last Post: - 25th July 2009, 01:39
  2. PWM and fade effect
    Last Post: - 10th July 2009, 11:58
  3. Port Indexing
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 25th September 2006, 13:33
  4. LED fade without PWM command
    By Nick in forum mel PIC BASIC
    Last Post: - 29th June 2005, 21:56
  5. Fade out an LED using PWM?
    By RossW in forum mel PIC BASIC Pro
    Last Post: - 6th August 2004, 20:59
