Need help with understanding PID control
Results 1 to 12 of 12
    Default Re: Need help with understanding PID control
    It's because the calculations are using the */ operator: 100 */ $0225 = 214
    Since the gain variables (kp, ki, kd) are Words the max gain would obviosuly be $FFFF which is equal to an actual gain of ~255. Care needs to be taken not to overflow the output when large gains are used in system where the error cn be large.
    Nov 2009
    London
    Thanks Henrik. So, is there any way I can tell what is the actual gain setting ( like 2.14 or 3.5 etc) before I multiply with 10 or 100. For example just by looking at lets say for example $0324?
    I tried the following code, but my duty stays at 255 and is not coming down after overshoot.
    'PROPORTIONAL VARIABLES
    Error_P Var Word
    Kp Var Word
    Kp=$0900
    Gosub Get_Sensor_Value ' Get value from sensor
    ' ----- PROPORTIONAL CONTROL----------
    Error_P=Set_Point-Sensor
    Drive_p=(ABS Error_P) */ Kp
    If Error_P.15 then Drive_P=-Drive_P
    Drive_T=Drive_T+Drive_P '(I used DriveT=Drive_T+... to keep some level of drive)
    Duty=Drive_T
    Gosub Duty_Mosfet
    Pause 250
    Goto Main
    Duty_Mosfet:
    If Duty>255 then Duty=255
    If Duty.15=1 then Duty=0
    HPWM 1,Duty,500
  1. PID help
    Last Post: - 4th November 2011, 07:32
  2. Replies: 0
    Last Post: - 27th March 2011, 21:10
  3. Re: PID control + radiant heating
    By Steve_88 in forum Off Topic
    Last Post: - 18th January 2011, 14:11
  4. Pid
    By colarsson in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 11:18
  5. PID control with Picbasicpro
    By swordman in forum mel PIC BASIC Pro
    Last Post: - 6th August 2004, 15:37
