using DS1307
Results 1 to 17 of 17
Thread: using DS1307
    Oct 2009
    Default Re: using DS1307
    Cheers - Between our replies I found that I could do as you suggested, although I didn't know about the $01 address part. I assume where I had $00 the is the RTCSec bit, so using the $01 tells the code to read from the second bit (RTCMIN) ?
    Thanks for your help
    Apr 2011
    Welches, Oregon
    Yes, but understand only that where you use the word "bit" is actually a byte. $00 is "%00000000", $01: "%00000000" ... like that. It is how you can read and write the AM/PM bit and read Status bits to verify the clock is running:
    IF RTCHour.6 = 0 then 24H mode enabled.
    Enjoy...
  1. ds1307
    By mel4853 in forum mel PIC BASIC Pro
    Last Post: - 8th January 2013, 10:46
  2. ds1307
    By jonas2 in forum Code Examples
    Last Post: - 2nd November 2009, 10:50
  3. DS1307 on fire
    By brid0030 in forum General
    Last Post: - 25th November 2006, 03:44
  4. DS1307 help
    By Orlando in forum mel PIC BASIC Pro
    Last Post: - 17th March 2005, 16:17
  5. Ds1307
    By miniman in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2005, 09:29
