using DS1307
Results 1 to 17 of 17
Thread: using DS1307
    Apr 2011
    Welches, Oregon
    Default Re: using DS1307
    You need not read any that you do not require.
    I2CRead SDApin,SCLpin,$D0,$01,[,RTCMin, RTCHour] ; read DS1307 chip
    Will begin reading at register $01 (note change I made to your code) and collect two registers in the variables (RTCMin, RTCHour) you provided. Like that you have BCD minutes and hours.
    Also, remove the leading comma in the variable list as: [RTCMin, RTCHour]
    Oct 2009
    Cheers - Between our replies I found that I could do as you suggested, although I didn't know about the $01 address part. I assume where I had $00 the is the RTCSec bit, so using the $01 tells the code to read from the second bit (RTCMIN) ?
    Thanks for your help
    Apr 2011
    Welches, Oregon
    Yes, but understand only that where you use the word "bit" is actually a byte. $00 is "%00000000", $01: "%00000000" ... like that. It is how you can read and write the AM/PM bit and read Status bits to verify the clock is running:
    IF RTCHour.6 = 0 then 24H mode enabled.
    Enjoy...
    Oct 2009
    Thanks for your help... The following code works fine for just hours and minutes.
    Posted here for reference should anyone else need this.
    18F4520 - running with a 20mhz crystal - 4x20 LCD
      __CONFIG    _CONFIG1H, _OSC_HSPLL_1H
      __CONFIG    _CONFIG2L, _PWRT_ON_2L
      __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H
      __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE  OSC 48  ; config settings 18F4580, 20mhz crystal
    ADCON1 = $0F
    clear
    	RTCMin var byte		' Minutes
    	RTCHour var byte	' Hours
    	RTCCtrl var byte	' Control
    SCLpin var PORTC.3               ' RTC pin - clk
    SDApin var PORTC.4               ' RTC pin - data
    Hours             var byte
    Minutes           var byte
    	CounterA var byte	' General purpose Variable
    	CounterB var byte	' General purpose Variable
    	CounterC var byte	' General purpose Variable
    	CounterD var byte	' General purpose Variable
    	SetMN var byte		' Minutes
    	SetHR var byte	' Hours
    'analog settings
    ADCON0 = 0                      'Set ADCON0
    ADCON1 = %00001111              'Set D i/o
    CMCON = 7                       'Disable Comparators
    PR2 = 249
    'Port settings
    CCP1CON = %00001100             '
    CCP2CON = %00001100             '
    TRISA  = %11101111              'set PORTA as all output apart from 0,1,2
    TRISB  = %00000011
    TRISD  = %00000011              'set PORTB as all output apart from 0&1
    DEFINE LCD_DREG  PORTB           ' LCD Data port
    DEFINE LCD_DBIT  0               ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB           ' LCD Enable port
    DEFINE LCD_EBIT  5               '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB           ' LCD Register Select port
    DEFINE LCD_RSBIT 4               '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4               ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4               ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000        ' Command delay time in us
    DEFINE LCD_DATAUS 50             ' Data delay time in us
    setHR = 12
    setMN = 01
    '	Save Minutes
    			CounterA=SetMN
    			Gosub ConvertBCD
    			RTCMin=CounterB
    '	Save Seconds
    			CounterA=SetHR
    			Gosub ConvertBCD
    			RTCHour=CounterB
    I2cwrite  SDApin,SCLpin,$D0,$01,[RTCMin,RTCHour]  ; read DS1307 chip
    I2CREAD SDApin,SCLpin,$D0,$01,[RTCMin,RTCHour]  ; read DS1307 chip
    	LCDOut $FE,$80
    If RTCHour.6=1 then
    CounterA=(RTCHour>>4)&$01                           ' Work-Out 12 or 24 hour Display for Hours
    CounterA=(RTCHour>>4)&$03
    CounterA=CounterA*10+(RTCHour&$0F)                  ' Display Hours appropriately for 12 or 24 hour Mode
    If RTCHour.6=1 then
    LCDOut $FE,$D4,#CounterA
    LCDOut $FE,$D4,#CounterA Dig 1,#CounterA Dig 0
    LCDOut ":",#(RTCMin>>4)&$0F,#RTCMin&$0F,"   "
    	Goto main
    ConvertBCD:
    	CounterB=CounterA DIG 1                        ' CounterA is the entry variable
    	CounterB=CounterB<<4                           ' CounterB holds the converted BCD result on exit
    	CounterB=CounterB+CounterA DIG 0
    It's all rough and ready... now to convert the Hours and minutes into the value for a counter and try this in my next version of aquarium lighting
    Thanks for your contribution - steep learning curve but I'm getting there
    Oct 2009
    OK, whilst the RTC is working fine with just reading and writing RTCHours and RTCMin, I'm having issues converting the time into minutes so I can use the variable Counter1 to store that value which is then used in the logic within my code to trigger case statements.
    For example 14:00 hrs would equate to 840 minutes as the counter is reset to 00:00 at midnight. 14 * 60 = 840. 14:01 would thus be 841 etc
    I've tried the following
    If RTCHour.6=1 then
    If RTCHour.6=0 then
    MM=(RTCMin>>4)&$0F+RTCMin&$0F
    Counter1 = (counterA*60)+MM
    But using this 13:57 gives a value of 784, when it should be 837.... anyone have any suggestions ?
    Oct 2009
    OK guys I need some help here.
    Here is the main part of the code which uses the timer overflow to generate the time, and from that derive the value for Counter1, which is then used to trigger the case statements and ramp up the lights, etc - This works. The percentages for the PWM are shown on the LCD and the case (Night, Dawn, Day and Dusk) all change depending on the logic.
    'clock routine
    ClockLoop: IF intcon.2=0 THEN ClockLoop	'Poll for TMRO overflow
    INTCON.2=0                              'Clear TMRO overflow flag
    HzTimer=HzTimer-$1000	                'decrement timer count
    IF HzTimer < $1000  THEN
    IF Col=10 THEN                          'update time'
    SS=SS+1
    IF SS=60 THEN   ' minute
    SS=0
    MM=MM+1
    IF MM=60 THEN    ' hour
    MM=0
    HH=HH+1
    IF HH=24 THEN HH=0
    counter1 = (HH*60)+MM
    Col=Col+1
    HzTimer=HzTimer+$7A12	                  'Add 0.5 seconds to count
    if Col=11 then
    Col=1
    LCDOut $FE,$D4,#HH DIG 1,#HH DIG 0,":",#MM DIG 1,#MM DIG 0
    'check what part of the cycle
    If Counter1 < Blue_on_Time then
    Blue_day_cycle = NIGHT
    if counter1 > blue_on_time and Counter1 > blue_off_Time and B_PWM > B_Min then
    Blue_day_cycle = DUSK
    if counter1 => blue_on_time and Counter1 < blue_off_Time and B_PWM < B_MAX then
    Blue_day_cycle = DAWN
    If Counter1< White_on_Time then
    White_day_cycle = NIGHT
    if counter1 > white_on_time and Counter1 > white_off_Time and W_PWM > W_Min then
    White_day_cycle = DUSK
    if Counter1 => white_on_time  and Counter1 < white_off_Time and W_PWM < W_MAX then
    White_day_cycle = DAWN
    '*** Do BLUE daily cycle
    select case Blue_Day_Cycle
    case DAWN
    lcdout $FE,$80+13,"DAWN "
    if ss//blue_delay_in = 0 then
    if ss != old_ss_blue then
    B_PWM=B_PWM+1
    old_ss_blue=ss
    if B_PWM = b_max then
    Blue_Day_Cycle = DAY
    case DAY
    lcdout $FE,$80+13,"DAY  "
    if B_max < B_PWM then
    B_PWM=B_PWM - 1
    if counter1 =blue_off_time then
    CASE DUSK
    lcdout $FE,$80+13,"DUSK "
    if ss//blue_delay_out= 0 then
    B_PWM=B_PWM-1
    old_ss_blue=ss
    if B_PWM = B_MIN then
    Blue_Day_Cycle = NIGHT
    case NIGHT
    lcdout $FE,$80+13,"NIGHT"
    B_PWM=B_min
    end select
    '*** Do WHITE daily cycle
    select case White_Day_Cycle
    case DAWN
    lcdout $FE,$C0+13,"DAWN "
    if ss//white_delay_in= 0 then
    if ss != old_ss_white then
    W_PWM = W_PWM+1
    old_ss_white=ss
    if W_PWM = W_max then
    White_Day_Cycle = DAY
    case DAY
    lcdout $FE,$C0+13,"DAY  "
    if W_max < W_PWM then
    W_PWM=W_PWM - 1
    if counter1 =white_off_time then
    CASE DUSK
    lcdout $FE,$C0+13,"DUSK "
    if ss//white_delay_out= 0 then
    W_PWM=W_PWM-1
    old_ss_white=ss
    if W_PWM = W_min then
    White_Day_Cycle = NIGHT
    case NIGHT
    lcdout $FE,$C0+13,"NIGHT"
    W_PWM=W_min
    end select
    'do the business of sending pulse to drivers
        hpwm 1,W_PWM,200
        hpwm 2,B_PWM,200
    'tidy up the display for the current percentage to remove stray zero's
    If (B_PWM * 100)/255 = 100 then
    lcdout $FE,$80,"BLUES  ",dec3 (B_PWM *100)/255,"%"
    If (B_PWM * 100)/255 =0 or (B_PWM * 100)/255 <10 then
    lcdout $FE,$80,"BLUES  ",dec1 (B_PWM *100)/255,"% "
    if (B_PWM * 100)/255 >=10 and (B_PWM * 100)/255 <100 then
    lcdout $FE,$80,"BLUES  ",dec2 (B_PWM *100)/255,"%  "
    If (W_PWM*100)/255 >= 100 then
    lcdout $FE,$C0,"WHITES ",dec3 (W_PWM *100)/255,"%"
    If (W_PWM * 100)/255 <=0 or (W_PWM * 100)/255 <10 then
    lcdout $FE,$C0,"WHITES ",dec1 (W_PWM *100)/255,"% "
    if (W_PWM * 100)/255 >=10 AND (W_PWM * 100)/255 <100 then
    lcdout $FE,$C0,"WHITES ",dec2 (W_PWM *100)/255,"%  "
    'Get and display the temperature
        OWOUT DQ, 1, [$CC, $44]                 ' Start temperature conversion
        OWOUT DQ, 1, [$CC, $BE]                 ' Read the temperature
        OWIN DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE]
        temperature = temperature */ 1600
        lcdout $FE,$D4+11,"TEMP ",DEC(temperature / 100),$DF,"C"
    GOTO Main
    So all I did was to add in a few new variables for the RTC - and modify the line to display the counter to reflect the change of variables. This also works to a fashion, in that the time is displayed correctly and when the logic is met the case changes from NIGHT to DAWN at the correct set time. However the LEDs do not ramp up, and the values for Whites and Blues remain at zero percent. I've done nothing else to the code, certainly not with the case statements or the logic behind them.
    If SetButton=0 then                     'if presed jump to the menu
    goto mainmenu
    ' check for manual override of the lights
    If H_butt = 0 then                      ' if pressed then change state of varible to 1
    Light=1
    If light=1 then                         ' If the variable is 1 then output full PWM to lights
        hpwm 1,255,200
        hpwm 2,255,200
    If light=0 then                         ' If the variable is low then set value to 0 an turn off the lights
        hpwm 1,0,200
        hpwm 2,0,200
    If M_butt = 0 then                      ' if pressed then change state of varible back to 0
    Light=0
    'clock routine
    timeH=(RTCHour>>4)                               'convert the BCD format of the hours register and store in variable timeH
    timeH=(timeH &$03)*10
    timeH=timeH+(RTCHour&$0F)
    timeM=(RTCMin>>4)
    timeM=(timeM &$07)*10
    timeM=timeM+(RTCMin&$0F)                         'convert the BCD format of the mins register and store in variable timeM
    Counter1 = (TimeH *60)+ TimeM
    LCDOut $FE,$D4,#TimeH DIG 1,#TimeH DIG 0,":",#TimeM DIG 1,#TimeM DIG 0
    case DAWN
    B_PWM=B_PWM+1
    old_ss_blue=ss
    case DAY
    B_PWM=B_PWM - 1
    CASE DUSK
    B_PWM=B_PWM-1
    old_ss_blue=ss
    case NIGHT
    B_PWM=B_min
    end select
    case DAWN
    W_PWM = W_PWM+1
    old_ss_white=ss
    case DAY
    W_PWM=W_PWM - 1
    CASE DUSK
    W_PWM=W_PWM-1
    old_ss_white=ss
    case NIGHT
    W_PWM=W_min
    end select
        hpwm 1,W_PWM,200
        hpwm 2,B_PWM,200
    GOTO Main
    The strange thing is, I have a diagnostics option so on the press of a button I can scroll through all the main variables so I can check that they match what's expected. These are all showing correct values, especially those for the fade in and fade out.
    I'm using the HPWM pins on the PIC (18f4520) which are on port C.1 and C.2. But whilst if there was a conflict of hardware that prevented the LEDs lighting, I would still of expected the LCD to show the increase in PWM values given by the fact the variables have values.
    Comments please
    Oct 2009
    This has got me stumped....
    'clock routine
    'ClockLoop: IF intcon.2=0 THEN ClockLoop	'Poll for TMRO overflow
    'INTCON.2=0                              'Clear TMRO overflow flag
    'HzTimer=HzTimer-$1000	                'decrement timer count
    'IF HzTimer < $1000  THEN
    'IF Col=10 THEN                          'update time'
    'SS=SS+1
    'IF SS=60 THEN   ' minute
    'SS=0
    'MM=MM+1
    'IF MM=60 THEN    ' hour
    'MM=0
    'HH=HH+1
    'IF HH=24 THEN HH=0
    'ENDIF
    'counter1 = (HH*60)+MM
    'ENDIF
    'ENDIF
    'Col=Col+1
    'HzTimer=HzTimer+$7A12	                  'Add 0.5 seconds to count
    'ELSE
    'ENDIF
    'if Col=11 then
    'Col=1
    'endif
    'LCDOut $FE,$D4,#HH DIG 1,#HH DIG 0,":",#MM DIG 1,#MM DIG 0
    timeM=(RTCMin>>4)
    If I comment out everything in red and uncomment everything in green, the code works, in that at 14:00 hrs (Counter1 = 840) the case statement changes from NIGHT to DAWN and the brightness percentage increases and the LEDs start to brighten. If I uncomment everything in red and comment out everything in green, the case changes from NIGHT to DAWN at 14:00 hrs, Counter1 = 840 but the brightness remains at zero and the LEDs remain off.
    Like I said, I could understand it if the brightness changed on the LCD but the LEDs remained off as this could point to a port config issue. But for it simply to ignore the values in the case statement and not work at all Its baffling and beyond me !
  1. ds1307
    By mel4853 in forum mel PIC BASIC Pro
    Last Post: - 8th January 2013, 10:46
  2. ds1307
    By jonas2 in forum Code Examples
    Last Post: - 2nd November 2009, 10:50
  3. DS1307 on fire
    By brid0030 in forum General
    Last Post: - 25th November 2006, 03:44
  4. DS1307 help
    By Orlando in forum mel PIC BASIC Pro
    Last Post: - 17th March 2005, 16:17
  5. Ds1307
    By miniman in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2005, 09:29
