Simple Reset code needed for pic12f675 Please Help!
Results 1 to 5 of 5
    Default Re: Simple Reset code needed for pic12f675 Please Help!
    Thank you, I really appreciate the help!
    You are welcome, I hope it is helpful.
    I changed the word loop to mainloop as loop is a reserved word in PBP 3.xx
    notice ADCON0
    bits 2 & 3 select the channel, bit 0 turns the AD on off and bit 1 is the GO/Done bit set to go, 0 means done which means you can check it to see if done.
    Aug 2003
    If you really wanted to go the long way round like that,
    you could use a variable to count the number of times your main loop is run,
    then when it reaches a certain value, simply use a spare pin to pull the MCLR.
    But it's better to fix it.
  1. Replies: 14
    Last Post: - 22nd January 2012, 05:06
  2. Help needed with source code
    By orangekitty in forum mel PIC BASIC Pro
    Last Post: - 30th October 2010, 11:06
  3. Simple TMR1 application example needed
    Last Post: - 4th February 2010, 10:52
  4. help with code needed
    By ccronin4 in forum mel PIC BASIC Pro
    Last Post: - 24th December 2005, 23:48
  5. PIC18 USB simple example needed
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 29th September 2005, 23:20
