Nch mosfet direct driven with pic
Results 1 to 9 of 9
    Feb 2012
    PERTH AUSTRALIA
    Default Nch mosfet direct driven with pic
    hI GUYS , looking for a bit of input on using these Nch Mosfet ( DMN3404L) and this Pch Mosfet( NX2301P) - see spec sheet attached
    and if the use of resistors in series, pic to the gate and or resistor pullup ( nch ) / pull down (Pch ) on gate is required
    The N ch has 500pf capacitance with a gate voltage threshold of 1.4 - 2v max , very low on Ohms
    the current PCB design is such that the Mosfet is close the LED or other device it switches ,
    with the CPU a max of 1200mm away and the tracks feeding the MOSFET are thick as possible ( board Layout to be reviewed )
    the Nch mosfets used to drive IR leds at about 100ma pulsed 38Khz one at a time
    regards
    Sheldon
    Feb 2012
    PERTH AUSTRALIA
    Default Re: Nch mosfet direct driven with pic
    it seems 100R in series with the NCh that drives just a normal LED is the go else when the pic is told to turn off the mosfet i need a pause after the command to allow the LED to turn off
    Aug 2003
    Why can't you switch the IR LED with a signal transistor, or directly from the pic pin?
    Dec 2010
    I have not looked at the datasheets for your specific devices, but in general you don't need any configuration of resistors - you can drive the gate directly from the PIC pin, as long as the pin can pull high and low. I do this all the time with N channel devices. If you intend to tristate the pin, you would want to add a resistor to the appropriate rail to make sure it is off (or on) in that situation.
    If you need 100 mA, directly driving simply won't work.
    Feb 2012
    PERTH AUSTRALIA
    yes the devices work ok with nch mosfets , connected to the IR LEDs , without a series resistors from the PIC , but as this will be in service a while i was wanting it to be robust
    as this board is 1.2 meters long with IR LEDS ( 15 off) along the the length it was practical for board layout and other components to put the mosfets close to the IR LED , this mean a long signal length from the pic , something i would have not normally done , where i would normally put the mosfet close to source and switched output can be a distance away.
    I have found that by putting series resistors on the NCh RBG led solves a problem of where a color , which was turned on/off using toggle ,and then another color turn on , would not , without a pause between the commands
    I like to put a 39 ohm r between the pic and the mosfet gate. I often find that failed fets love short drain to gate on failure and in low volt apps a small r will save the pic chip. its also nice to have a 1k r between source and gate to ensure fet is kept "off " when pic output is in high impedance state .thats probable whats keeping your leds turned on. its important to remember that mosfets are gate charge dependent devices and that correct switching means rapid and thorough charge/discharge of the gate capacitance
    Feb 2012
    PERTH AUSTRALIA
    thanks guys , i tending toward a series resister of about 100R and the 1K pull up( Nch)/ down ( PCh) on the gate just be safe , as fixing problems down the road , is not a good design make , its pain on so many fets but better to be safe , and 4 and 8 resistor arrays make it bit less work for smd
    Dec 2010
    You can certainly add the extra components - it's your budget - but series resistors are usually left overs from transistor designs. If you are having an issue with turn on / off times, technically, series resistors will make it worse. They will, however, help improve noise immunity if that's a concern, and it might be with your long runs.
    Pull up / down resistors are only useful if you ever tri-state the output. If you always drive either high or low, all they do is waste current in one of those states. They are useful during start-up if there's a risk of damage with an unknown gate state, (say where you could short the supply by having 2 devices on in some designs).
    I used to make those same circuit choices (series resistors and pull up/down) automatically, until I sat down and actually did the circuit analysis. In some cases they hurt more than help. (The same is true of liberally sprinkling decoupling capacitors, but I digress)
    Feb 2012
    PERTH AUSTRALIA
    yes the only issue i am having is having to add the pauses to turn off /on when driving the the Nch on the rgb at the moment added the series resistors solved that , those are only 200mm runs , the IR leds seem fine without resistors and those signal runs are long at up to 1200mm ,
    i have been looking at moving the mosfets closer to the cpu on the next board layout.
    not seen much that much noise in the switching even with the long runs , but ill look at it closer
  1. Direct PIC to PC without MAX232
    By acjacques in forum Serial
    Last Post: - 23rd October 2014, 22:32
  2. 24v driven MosFET
    By netstranger.nz in forum General
    Last Post: - 19th May 2012, 08:50
  3. Help needed - MOSFET driven by PWM
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 06:02
  4. Self Destroying Mosfet with PIC
    By Josuetas in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2007, 17:42
  5. Pic driven digital audio delay
    By skimask in forum Off Topic
    Last Post: - 19th April 2007, 21:42
