Newbie - Advise Please
Results 1 to 3 of 3
    tracking's Avatar
    tracking Guest
    Question Newbie - Advise Please
    hELLO
    Started using PBP with Codedesigner and trying to learn would appreciate help on the following:
    What I'm trying to do is:
    SerIn2 pinin,16572,200,start,[STR tempStr\12\"#"]
    This seems OK
    but how do I use whats in the string for example
    IF tempStr = "abcd" Then - This will not work
    got loop
    EndIF
    Advise Please
    Thank You
    Lyn
    You have to test individual elements in your string array.
    IF tempStr(0) = "a" then
       IF tempStr(1) = "b" then
          IF tempStr(2) = "c" then
            IF tempStr(3) = "d" Then
              goto loop
            End If
          End If
       End IF
    End If
    Unfortunately, PBP will not test the whole string as a single argument.
    You could also use the wait modifier to wait until ASCII characters abcd
    arrive, then receive the remainder of your data packet in the array.
    SerIn2 pinin,16572,200,start,[WAIT("abcd"), STR tempStr\8\"#"]
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    tracking's Avatar
    tracking Guest
    Default Thanks Bruce
    Thanks Bruce every bit of knowledge helps
    Cheers
    Lyn
  1. Newbie making an ignition timer
    Last Post: - 5th August 2012, 18:45
  2. Newbie problem :)
    By sokrad in forum mel PIC BASIC Pro
    Last Post: - 25th January 2008, 11:34
  3. Newbie: Temperature measurements
    By Budda in forum General
    Last Post: - 30th March 2007, 10:56
  4. PIC Newbie
    By azmax100 in forum Schematics
    Last Post: - 23rd February 2007, 05:52
  5. request for a newbie forum
    By nimonia in forum Forum Requests
    Last Post: - 20th May 2006, 10:01
