DS18B20 ID saving To and Reading From EEPROM
Results 1 to 15 of 15
    Dec 2011
    Default Re: DS18B20 ID saving To and Reading From EEPROM
    I'm back to try and resolve this. I can not assign each temp sensor (6 of them) a different pin as the motherboard is already produced, I am just trying to improve things a little. So all I need to figure out is how to get an array into the select case:
    I have tried:
    SELECT CASE sensor
        CASE 1 :LOOKUP hexbyte,[STR sensor1\8], col
    but that does not work
    In my orginal code I have:
    Select Case sensor
            Case 1 :LOOKUP hexbyte,[$28,$1E,$F5,$24,$03,$00,$00,$B8], col
    Lets say the array sensor1\8 is $28,$1E,$F5,$24,$03,$00,$00,$B8
    Hope this makes sense.
    Sep 2010
    Las Vegas, NV
    Should lookup have a : before it?
  1. Reading temperature using multi DS18B20
    By KVLV in forum Code Examples
    Last Post: - 3rd November 2017, 20:48
  2. Reading DS18S20 and DS18B20 In Same Program
    By Larryd in forum General
    Last Post: - 27th January 2013, 06:57
  3. ds18b20 not reading on 16f676
    By revelator in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2009, 01:20
  4. DS18B20 error reading
    By Gaetano in forum mel PIC BASIC Pro
    Last Post: - 29th August 2007, 17:21
  5. Reading 5 DS18B20 Problem
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 30th August 2005, 21:51
