Thanks Dwight, I originally used your code and it worked great! but now I want it all done in program. I want to read the device ID, Save it to EEPROM (incase of power failure or what not), and at program start read all the device ID arrays (pre-load it) for use in the program.
That way if I need to change one I wont have to load the read device ID program, get the ID, write it down, go into main program change the string, complie and program. It will be kind of like a hot swap with a selection in the menu to install a new sensor.
