Broken Case statement Logic
Results 1 to 10 of 10
    Tom, Where is the value for the variable TC1 comming from?
    Feb 2005
    Bellevue
    It is coming from an array of 2 HEX bytes, which are then converted to binary. In the case I am using, the
    the value '44308' is what TRACID_ID is in this example..
    SSD4= (ssmax[1]>>4)
    SSD3= (ssmax[1] & $f)
    SSD2= (ssmax[0]>>4)
    SSD1= (ssmax[0] & $f)
    TracID_D=(ssd4*4096)+(ssd3*256)+(ssd2*16)+ssd1' convert to dec
    TC1=(TracID_D/1600)
    I have attached a spreadsheet that does this also. It uses an "INT" function to keep the result of the TracID_D/1600 rounded to 27. In PBP I need an equivalent function. Otherwise the answer is 27.7 and that messes up the CASE statement.
    IN the excel example, if you remove the INT function, it gives 27.7 also.
    TG
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 08:10
  3. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 19:19
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 15:04
  5. Interrupt/timer not really interrupting...
    Last Post: - 22nd May 2005, 22:05
