Broken Case statement Logic
Results 1 to 10 of 10
    Feb 2005
    Bellevue
    ... actually if I have PBP show me the 'DIG1' of the value that was 27, it is actually 27.7... it needs to be just 27.. How does one round using PBP?
    Tom, Where is the value for the variable TC1 comming from?
    Feb 2005
    Bellevue
    It is coming from an array of 2 HEX bytes, which are then converted to binary. In the case I am using, the
    the value '44308' is what TRACID_ID is in this example..
    SSD4= (ssmax[1]>>4)
    SSD3= (ssmax[1] & $f)
    SSD2= (ssmax[0]>>4)
    SSD1= (ssmax[0] & $f)
    TracID_D=(ssd4*4096)+(ssd3*256)+(ssd2*16)+ssd1' convert to dec
    TC1=(TracID_D/1600)
    I have attached a spreadsheet that does this also. It uses an "INT" function to keep the result of the TracID_D/1600 rounded to 27. In PBP I need an equivalent function. Otherwise the answer is 27.7 and that messes up the CASE statement.
    IN the excel example, if you remove the INT function, it gives 27.7 also.
    TG
    Feb 2005
    Bellevue
    WOW!! I just tried setting my value to 27 manually, and it STILL does not work!!
    Check this out:
    TC1=27
    Select Case TC1
    case 0
    TracID1 = " "
    case TC1 < 27 'A-Z
    TracID1 = TC1 + 64
    case TC1 >= 27 '0-9
    TracID1 = TC1 + 21
    case 37
    TracID1 = ":"
    case 38
    TracID1 = "."
    case else
    TracID1 = "$"
    End Select
    The result is "[", when it should be "0"!!! How could I be setting a value of "27" and having this kind of result?
    TG
    Tom, If you would please try the code exactly as I have written it in my first reply and tell me what the results are.
    Feb 2005
    Bellevue
    Wink
    The answer was to not use the CASE statement at all.. It looked like it was failing somehow internally. So I moved to:
    If TCX = 0 then TracID1 = " "
    If TCX < 27 then TracID1 = TCX+64
    If TCX >=27 then TracID1 = TCX+21
    If TCX = 37 then TracID1 = ":"
    If TCX = 38 then TracID1 = "."
    if TCX > 38 then TracID1 = "$"
    I think the code is smaller, and best of all it works.
    Tom, It only goes to show, There's more than 1 way to skin a cat.......
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 09:10
  3. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 20:19
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. Interrupt/timer not really interrupting...
    Last Post: - 22nd May 2005, 23:05
