PIC18F4620 Write Command
Results 1 to 6 of 6
Threaded View
  1. #6
    Feb 2009
    Default Re: PIC18F4620 Write Command
    Hi! Good day! Henrik,
    So why did you try writing to $4205 then?
    I am using the program which my senior written and him already left the company. So, i not sure what is going to be happen using that command. Now, i understand from your explaination.
    Sorry for making you confuse.
    Let me show u the exact code that found error part.
    'Extract part of the code that have an error
    STEP_SELECT:
        read $101,STEP_ADDRESS
        STEP_ADDRESS = STEP_ADDRESS + 1
        WRITE $101,STEP_ADDRESS
        NG_COUNTER = 0
        write $103,NG_COUNTER
        DEBUG "CHECKING STEP_ADDRESS = ",DEC STEP_ADDRESS,10,13
    'Here, the result still can see at hyperterminal screen
        if STEP_ADDRESS = 1 then MULTIMETER_JUDGE
        if STEP_ADDRESS = 2 then ADDR_30
        if STEP_ADDRESS = 3 then ADDR_31
        if STEP_ADDRESS = 4 then ADDR_32
        if STEP_ADDRESS = 5 then ADDR_33
        if STEP_ADDRESS = 6 then ADDR_34
        if STEP_ADDRESS = 7 then ADDR_35
        if STEP_ADDRESS = 8 then ADDR_36
        if STEP_ADDRESS = 9 then ADDR_37
        if STEP_ADDRESS = 10 then ADDR_38
        if STEP_ADDRESS = 11 then ADDR_39
        if STEP_ADDRESS = 12 then ADDR_40
        if STEP_ADDRESS = 13 then ADDR_41
        if STEP_ADDRESS = 14 then CHARGING_CHECK
        if STEP_ADDRESS = 15 then CHARGING_CHANGE_DC
        if STEP_ADDRESS = 16 then END_PROCESS
    goto STEP_SELECT
    CHARGING_CHECK:
        HIGH RLY5_1_CHARGING_SUPPLY
        PAUSE 1000
        LOW RLY5_1_CHARGING_SUPPLY
        goto MULTIMETER_JUDGE
    goto STEP_SELECT
    MULTIMETER_JUDGE:
        READ $101,STEP_ADDRESS:WRITE $101,STEP_ADDRESS
        IF STEP_ADDRESS = 0 then
            DEBUG "STEP_ADDRESS =  ",DEC STEP_ADDRESS,10,13
            serOut GPIB_TX,N9600,["F5,R5,PR2,CO1,HI+00.200E-3,LO-01.000E-3",13]
            GOTO CONT_CURRENT_CHECK
        IF STEP_ADDRESS = 1 and VERSION_SW = 1 then
            DEBUG "(J4) STEP_ADDRESS =  ",DEC STEP_ADDRESS,10,13
        	SerOut GPIB_TX,N9600,["F5,R7,PR2,CO1,HI+090.00E-3,LO+070.00E-3",13]
        IF STEP_ADDRESS = 14 THEN
    'At here, the result can't see at hyperterminal screen...i wonder why this happen?
        	SerOut GPIB_TX,N9600,["F5,R7,PR2,CO1,HI+420.00E-3,LO+380.00E-3",13]
    CONT_CURRENT_CHECK:
    I only show the part of the program that error occurred. Hopefully u can understand that.
    TQ and BR
  1. Required Time for WRITE Command
    By rsocor01 in forum General
    Last Post: - 1st December 2011, 00:21
  2. EEPROM WRITE Command
    By aajgss in forum mel PIC BASIC Pro
    Last Post: - 20th October 2011, 06:58
  3. EEPROM Write command with interrupts??
    By Elnino in forum General
    Last Post: - 23rd November 2009, 06:44
  4. help with write command
    By cphillips82 in forum General
    Last Post: - 20th April 2008, 23:49
  5. Using the Write Command
    By in forum mel PIC BASIC Pro
    Last Post: - 16th April 2003, 02:09
