hi guys , not sure why this happens can someone advise
problem - RGB LED has 3 outputs from Pic connected to it and assigned variables , PWR_LOWLED(red) , PWR_LED (blue),OK_LED(green)
In the follow code , all works ok as expected , the PWR_LOWLED , is toggled , the PWR_LED is turned off
However in this code when i put the command to turn off the PWR_LED = 0 before the toggle PWR_LOWLED command , the PWR_LED remains on , and i dont see why it is the caseCode:if T0Count1 = Flash_rate and IR_RX_PWR_Low = 1 then toggle PWR_LOWLED ' Flash PWR_LOWLED pwr_led =0 ' turn off PWR_LED T0Count1=0 ' clear counter endif
any advise on why
Sheldon
Code:if T0Count1 = Flash_rate and IR_RX_PWR_Low = 1 then pwr_led =0 ' turn off PWR_LED toggle PWR_LOWLED ' Flash PWR_LOWLED T0Count1=0 ' clear counter endif
