Problem with 16F886 and LCD on PortC
Results 1 to 7 of 7
    Sep 2013
    Default Problem with 16F886 and LCD on PortC
    Hi, I write a program to test LCD and I see on first line black squares.
    What's wrong ?
    The LCD is OK, i have test with 16F690 on PortC and work.
    This is my code:
    @ __config _CONFIG1,_WDT_OFF & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    @ __config _CONFIG2, _WRT_OFF
    ANSEL=0 'toate porturile sunt digitale
    ANSELH=0
    ;******** legaturi display 2x16 caractere *******
    DEFINE LCD_DREG PORTC ;PortC folosit pentru date
    DEFINE LCD_DBIT 0 ;pinul 0 este primul pin de date conectat
    DEFINE LCD_RSREG PORTC ;portC folosit pt. pinul RS
    DEFINE LCD_RSBIT 5 ;Register select pin
    DEFINE LCD_EREG PORTC ;foloseste PortC pentru pinul E
    DEFINE LCD_EBIT 4 ;Enable pin
    DEFINE LCD_BITS 4 ;bus pe 4 biti
    DEFINE LCD_LINES 2 ;LCD cu doua randuri de caractere
    Pause 500
    Bucla:
    Lcdout $FE,1 ;clear display
    Lcdout $FE,2 ;return home
    Lcdout "TEST TEST"
    pause 3000
    goto Bucla
    Default Re: Problem with 16F886 and LCD on PortC
    Have you searched the forum for similar problem?
    Look at this from similar chip:
    http://melabs.com/samples/LABX1-16F887/lcdx.htm
    Came from: http://www.picbasic.co.uk/forum/show...87+lcd+digital
    Sep 2013
    I try these and... nothing. The program run (I put a LED who blink). Any advise, please ?
    Oct 2009
    Utah, USA
    Is it possible that the CONTRAST on the LCD is set too high?
    Dwight
    Sep 2013
    Solved. DB4 from LCD not conected Thanks.
    What about analog, pwm or some pther feature enabled on selected ports?
    Sep 2013
    I use this
    ANSEL=0 ;porturile A si B sunt digitale
    ANSELH=0
    ADCON0.0=0
    SSPCON.5=0 ;dezactiveaza portC serial
    RCSTA.7=0
  1. Problem proramming PIC 16F886 with PICKIT2?
    Last Post: - 11th January 2012, 23:23
  2. Problem with porta for 16F886(PIC 28X1)
    By Anghel Cosmin in forum Off Topic
    Last Post: - 26th February 2009, 13:07
  3. 18f4550 portc.4 and portc.5 problem
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 12th October 2008, 20:52
  4. 16f886 interrupt on portB problem
    By antonjan in forum mel PIC BASIC Pro
    Last Post: - 8th October 2008, 20:06
  5. LCD problem on portC
    By BobSpencerr in forum mel PIC BASIC
    Last Post: - 28th February 2007, 05:14
