PIC16F84A Matrix LED Display
Results 1 to 8 of 8
    Dec 2011
    Malabe, Sri Lanka
    Cool PIC16F84A Matrix LED Display
    Hi Friends,
    This is a PIC16F84A Microcontroller based matrix LED Display. It uses 7x15 (or 8x16) LED Matrix to display characters.
    The circuit uses two 4017 IC s to move the characters.
    Use the following link to download schematic, source codes and compiled hex files -
    Documentation is also added with details of how to display your own message.
    http://www.manelsoft.com/projects/pi...d_display.aspx
    Good Luck.!
    Sep 2010
    Las Vegas, NV
    Default Re: PIC16F84A Matrix LED Display
    Did you hook up your matrix exactly like the schematics out of the PIC Programming handbook? If so, I don't see how they work. I've been shown up many times in electronics and it might happen again here so here goes.
    On the 7 x 15 schematic the left hand CD4017 pin 6 is hooked directly to ground along with the base of the first column transistor. On either schematic I don't see how any diode is positively biased. None of the LEDs have a positive voltage applied to the anodes. If a high is to come from the PIC it's blocked by the right most column LEDs.
    I haven't had a chance to look at the code and frankly I wouldn't know an error in assembly if it had a prompt. I do plan on using your code in a project when I get some time. Thanks and let the schooling begin.
    I don't understand why column 15 is wired differently than the others.
    I think this is how it should be wired. The original had all the pic outputs shorted?
    Name:  LED Matrix.jpg
    Sep 2010
    Las Vegas, NV
    I think you're correct in wiring the rows to a port pin on the pic.
    After looking at the datasheet I see the 16F84 can sink/source 25mA per pin. Now I see why you'd want to use that chip. How would you do it with a 16F877A where the pins are not as robust? That was the chip I was planning on using is the reason I'm asking.
    Dec 2011
    Malabe, Sri Lanka
    Hi Friends, There was a mistake in the schematic. Thank you all for showing it. I fixed it. Please see the corrected one.
    Dec 2011
    Malabe, Sri Lanka
    @mark_s : Yes you are correct, There was a mistake in the Schematic, I fixed it. Thank you very much, Please see the corrected one.
    Quote Originally Posted by AvionicsMaster1 View Post
    I'd sink via transistors; cheap and simple.
  1. LED Matrix display
    By Art in forum General
    Last Post: - 5th October 2013, 04:06
  2. SureElectronics LED Dot Matrix Display
    By DanPBP in forum Off Topic
    Last Post: - 4th October 2009, 20:10
  3. 5x7 LED Matrix Scrolling Display
    By roycarlson in forum mel PIC BASIC Pro
    Last Post: - 4th August 2008, 23:50
  4. 245 Led Matrix Display (as constructed by Magu)
    By magu in forum Code Examples
    Last Post: - 29th June 2007, 00:07
  5. Replies: 0
    Last Post: - 20th October 2005, 05:43
