Print circuits directly with inkjet printer
Results 1 to 4 of 4
    Default Print circuits directly with inkjet printer
    Bombay, India
    Default Re: Print circuits directly with inkjet printer
    From the kickstarter webpage FAQ linked here http://www.kickstarter.com/projects/...circuit-boards
    What is the minimum size (of trace / gap) that the printer can print?
    The printer has a resolution of 600 DPI and we've tested making tracks/pads down to SOIC components (pin spacing of 1.27mm) very reliably. We are still pushing the limits to get even finer resolution and be able to use teeny tiny components.
    What chemicals does the printer use and are they dangerous/hazardous?
    The printer uses Silver Nitrate and Ascorbic acid. Silver Nitrate has been used in applications such as photography for centuries, and while we wouldn’t recommend serving the ink up with dinner, the finished circuits are safe to handle. Ascorbic acid is nothing more than vitamin C.
    Looks like a promising first step has been taken. The 1.27mm barrier seems big at this moment. Chips are getting tinier by the day and pitches of <0.5mm are becoming the norm.
    Bombay, India
    Miami, Florida USA
    Hi. Conductive printing has been around for a while. Here is a company where I got some free samples probably about two years ago.
    http://topflight.com/capabilities/conductive.htm
    They sent me some printed circuits done with conductive ink on paper and on a transparent sheet. The only bad thing about this is that you can not solder any component to these circuits, so they can only be used as a PCB antenna, connection strips, etc.
    Now, been able to do this at home with an inkjet printer is a nice advantage.
    Anonymous
  1. Replies: 20
    Last Post: - 25th May 2012, 15:37
  2. Replies: 1
    Last Post: - 15th December 2010, 14:30
  3. LCD 16x2 HD44780U on 3V pic Directly?
    Last Post: - 28th April 2008, 15:04
  4. Driving a mosfet directly?
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 12th July 2007, 07:45
  5. Interrupts interfering with PRINT
    By lsteele in forum General
    Last Post: - 21st September 2006, 20:44
