I'm at a loss
Results 1 to 17 of 17
Thread: I'm at a loss
    Jan 2010
    Default I'm at a loss
    Hello,
    OK, can't seem to figure this one out. I have a PIC16F628A that I have written code for. I try to program it and I get this, "Target Device does not match selected device". Now, the funny part is this...I have the microcontroller device ID entered correctly, as well as the ICSP pins connected correctly.
    When I've made a mistake in the past on other chips and clicked program, the above message occurred immediately. What's happening now is the status bar runs about 3 times and then I get the message. It looks like it's going to program, but then it fails. Any thoughts? It's not my programmer because it'll program other chips, but as soon as I try to program the 628A, it fails after 3 status bar sweeps. Thoughts?
    Default Re: I'm at a loss
    Please post your code & a picture of MCS if you can. I will assume you have selected the appropriate PIC in MCS, yes?
    Are you using MCS Plus? Does it support ICD for that chip?
    Miami, Florida USA
    Hmm, you usually get that message immediately not after three sweeps. Is that message showing when the programmer is doing the verification? Try to use programming only without verification. Are you using the diode in the Vpp chip pin?
    Anonymous
    Bombay, India
    If you are programming in system, try doing it with the target power turned on. Maybe the PICKIT is unable to support the current drain. I've seen similar, but only when powered by the PICKIT-II or III. If you're programming the chip stand-alone, I don't know. Maybe a short video showing the problem will help diagnosis.
    Jun 2004
    Michigan
    Sounds like you have some capacitance on one of the programming lines delaying a signal.
    Chuck Hellebuyck
    Electronic Products
    http://www.elproducts.com
    [email protected]
    Quote Originally Posted by ERMEGM View Post
    Hello,
    I always get such a message when I forget to enable power to the target with my PK2 or 3 ...
    moreover, the Pickit current capacity is limited ... sooo, couldn't your board draw too much current ??? ( as you talk about ICSP ...)
    and in the end, I remember a Microchip errata sheet about this subject for some series of those programmers ...
    Sep 2010
    Las Vegas, NV
    I'm not familiar with the Pickit but I have gotten a similar message when I haven't properly isolated the programming pins. I usually put a switch in the circuit to disconnect the rest of the circuit. If you look in the manual it recommends some minimum values when connecting your circuit.
    Jan 2010
    Thanks for the replies guys, but I am not using a Pickit. I have setup my boards to match the pin layout of my U2 programmer. I just use a wire harness from the U2 to my boards. It's quick and easy that way.
    What I meant about the sweeps is the status bar indicator. It usually fills about 3 times and then it would fail.
    I don't know what the problem was, but I placed another 628A on another board and tried programming it. That worked. I removed the first PIC on the first board and replaced it with the second PIC. Tried to program the second PIC on the first board and it failed immediately, however, I found a very tiny solder joint between 2 pins and I removed it. Now it works fine.
    Don't know if something was wrong with the first PIC or if there was a tiny solder joint, but I'll have to play with that PIC later. Don't know why it would run through it's sequence and then fail.
    I'd post some code, but it's over 1000 lines. But with respect to errors in the code, the PIC would still be programmed with the faulty code and fail on run, not programming.
    And yes, the correct PIC was listed in both programs.
    Thanks again guys.
    Tony
    I figure it can erase and program just fine with the solder jumper, but then fails on the verify. Most likely why you see the status bar fill a few times then fail.
    AKA Captain Obvious
    Aug 2003
    More likely it screws up the erase, and the programming as well, but doesn't know that until it tries to verify.
  1. Power loss - Brown out?
    By clocks in forum General
    Last Post: - 25th October 2010, 11:56
  2. Strange pic 16f877a memory loss
    By DavyJones in forum General
    Last Post: - 6th July 2009, 21:27
  3. Memory Loss??
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 24th October 2006, 12:10
  4. 8 port Signal Loss Detector, possible to use a pic?
    By jamie_s in forum mel PIC BASIC Pro
    Last Post: - 20th March 2006, 16:59
