Minimum Vref Voltage?
Results 1 to 4 of 4
    Default Re: Minimum Vref Voltage?
    1.1V won't work. Look at table 17-14 in the datasheet.
    It says that the minimum voltage difference between VRef- and VRef+ is 2.0V. If VRef- is connected to GND then the minimum voltage at VRef+ would be 2.0V.
    However, it ALSO says that VRef+ must be at least AVdd-2.5 so if you're powering the analog section of the PIC with 5V then the minimum voltage at VRef+ is 2.5V.
    Running the PIC at 3.3V and using a 2.048V reference gives you a resolution of 2mV.
    Other options is to add a front end to your signal, getting its amplitude up, or use an external ADC chip.
    Dec 2010
    To express what Henrik said a bit differently, the device datasheet says the device output will change 2.05 V over the full temperature range. If you are able to match that perfectly with Vref, then you will have the maximum resolution possible, since the full scale of the encoder would exactly match the full swing of the source voltage. So if you are going to use a 10 bit ADC, it's simply not possible to get more than 2 mV accuracy, and with quantizing errors, and offset errors, 5 or 10 is more likely. Alternatives? There are some PICs with 12 bit ADC, or restrict the temperature range, or do something creative with op-amps and multiple pins.
  1. Replies: 7
    Last Post: - 22nd January 2012, 05:50
  2. Convert a 'signed' Word to a Long with minimum manipulation ?
    By mr.sneezy in forum mel PIC BASIC Pro
    Last Post: - 29th May 2010, 07:26
  3. Minimum power modes for PIC18LF4620
    Last Post: - 6th February 2008, 02:30
  4. Minimum power operation - 16F877A
    Last Post: - 2nd March 2006, 03:44
  5. switching external vref+ and vdd vref
    By alejandro_halon in forum mel PIC BASIC Pro
    Last Post: - 16th February 2005, 21:13
