Stumped with word variable
Results 1 to 31 of 31
    Oct 2009
    Default Re: Stumped with word variable
    Cheers Richard, will give that a go.
    Guess I need to use the same method to write the value to memory ie write 10,blue_on_time.lowbyte and write 11,blue_on_time.highbyte
    yes its hard to remember wether the data statement saves words as highbyte first or not
    and then does the write word do the same ?, to read them back properly you must get it right.
    but write 1 ,word wordvar and read 1, wordvar is the way to go if you can't be bothered understanding what happens
    data @1 ,1,2 ; (wordvar.highbyte),( wordvar.lowbyte) $0102 =258 the question is ,is data @1,word 258 is it the same thing try it and see
    the easy way out if your not sure about data is to :-
    write 1, wordvar.highbyte, wordvar.lowbyte
    read 1 , wordvar.highbyte,wordvar.lowbyte
    its less efficient but it leaves no doubt.
    you could always read the manual or just experiment to find out , the trick is though to be able to remember it
    for next time
    Oct 2009
    I had referred to the manual, but just didn't comprehend how this worked...
    Oct 2009
    Uhmmm.
    Just tried
    write 10,Blue_on_Time.highbyte
    and on compiling it complains of illegal character, with a code [108].
    I've gone through the code and it compiles fine if I remove the .highbyte .... confused !!
    I copy/pasted the above line into a blank program, added Blue_On_Time VAR WORD to the top and it compiled just fine for a 16F628.
    Try removing the complete line, then re-enter it or copy/paste it from your own post. Perhaps there's some strange hidden character or something lurking. Like I said, compiles just fine here.
  1. When variable may not fits into WORD limitations
    Last Post: - 16th July 2013, 09:26
  2. How to isolate 10 bits from word variable?
    By rcbandwidth123 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 20:18
  3. adding new word variable ?
    By iugmoh in forum General
    Last Post: - 21st February 2008, 00:26
  4. WORD vs BYTE variable lengths
    By bartman in forum General
    Last Post: - 28th November 2005, 21:16
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
