Hello,
Thanks all for your comments.
i recheck hardware and all seems ok.
i'm going crazy with this one. defective ic? its uncommon...
Henrik: can post hex to see if any diference? do you use default settings file?
thanks again,
Paul
Hello,
thanks again,
Paul
Have you verified that MCLR is at Vcc?
LED connected with correct polarity and verified to be working?
Verified that the programmer and its application is working correctly, can you program other chips?
Yes, I've compiled your code with the PBP default CONFIG, which I quote here for reference:This is the code I compiled, using PBP 3.0.7.4Code:#CONFIG __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF #ENDCONFIGAnd here's the resulting hexCode:Define OSCCAL_1K 1 DEFINE OSC 4 CMCON = 7 OPTION_REG.7= 0 GPIO = %00000000 TRISIO = %00000001 Start: HIGH GPIO.0 PAUSE 1000 LOW GPIO.0 PAUSE 1000 GOTO Start ENDAgain, it works fine here. 10k pullup on MCLR, 1k5 in series with LED on GPIO.0Code::020000040000FA :100000002828A301A200FF30A207031CA307031C9A :1000100023280330A100DF300F200328A101E83E90 :10002000A000A109FC30031C1828A00703181528FC :10003000A0076400A10F152820181E28A01C222844 :1000400000002228080083130313831264000800B1 :10005000FF238316900083120730990083168113C3 :1000600083128501831601308500831205148316DF :100070000510FA3083120120051083160510FA309E :0A0080008312012036286300432894 :02400E00FC3F75 :00000001FF
I guess you actually have to read the hyperscript numbers. Sorry for the inconenience.
