1 KHz Sine Wave
Results 1 to 13 of 13
Thread: 1 KHz Sine Wave
    Nov 2013
    Default Re: 1 KHz Sine Wave
    extract:
    " Arduino Sine wave Generator using the direct digital synthesis Method
    Here we describe how to generate sine waves with an Arduino board in a very accurate way. Almost no additional hardware is required. The frequency range reaches form zero to 16 KHz with a resolution of a millionth part of one Hertz! Distortions can be kept less than one percent on frequencies up to 3 KHz. This technique is not only useful for music and sound generation another range of application is test equipment or measurement instrumentation. Also in telecommunication the DDS Method is useful for instance in frequency of phase modulation (FSK PSK)."
    http://education-tn.blogspot.com/201...-circuits.html
    Aug 2003
    Am I the only one who can't see the images on that page?
    EDIT,, ok, maybe he has just deleted the early example pictures.
    That's interesting, I also want to do a frequency counter where the input
    is a buffered sine wave, and both for the same project!
    It has undergone some transformation since I got it
    Must be, I can see pictures & tables & code, lucky link for me as I was wanting an example in C for a lookup table. Check your ADBLOCK & script blocker settings, maybe you're blocking the images from there. . . I would say it's a safe bet that radio was old when you were born, what is it?
    Aug 2003
    Yes, but when I'm dead, it's going to be newer than that
    There is another box that ends up going under this, to interface with it,
    but without any new chassis holes (i.e.. nothing that can't be reversed.
    It's the most ambitious for me yet.
    RF probe frequency counter to display the LO frequency minus the Intermediate frequency for
    digital station display, and then later, feedback to turn the original dial with a low geared stepper motor.
    It is difficult to introduce a new micro or PSU, into an AM radio.
    Aug 2003
    Your lookup table in C is the same as using a PBP array.
    byte[36] of the static declared array is index 35.
    The size you declared the array, you start counting from one like a Human,
    but when you go to address it, it's back to programming, and you count from zero.
    Aug 2003
    Don't know what to say... Old tube radios have analogue components, and unstable oscillators
    Will have to do the Huff Puff technique to stabilise it with analogue components.
    This is not yet fit for a robot tuner.
    Kinda got a rule about completing projects, and number of simultaneous projects!
    Aug 2003
    Lol, it just increments/decrements the index for a lookup table that is a pre-generated sine wave
    to send to PWM.
  1. Sine wave power inverter
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2017, 05:16
  2. Sine wave
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 18th May 2009, 03:31
  3. square to sine wave help
    By TONIGALEA in forum General
    Last Post: - 2nd July 2006, 09:32
  4. Sine wave generator
    By Mario in forum Forum Requests
    Last Post: - 16th March 2006, 23:30
  5. 40 kHz wave
    By RUBiksCUbe in forum mel PIC BASIC Pro
    Last Post: - 14th December 2005, 20:01
