For several days I'm trying to use the MSSP
The complete project is to use 4 x PIC18F45K22 as slave and another one as Master.
At this time I just simulate data between 1 slave and the master with Proteus 8 and... the simulation works.
Unfortunately, test with my PCB makes me crazy.
When Master asking to slave with a "?" I expect to receive "!WAY0625"
or HEX: 21 57 41 59 30 36 32 35
This is simulation give, but in fact (Real PCB) the slave never answer the good message beginning by "!"
don't care about the "41 hex" in place of "3F hex", this is because I'm trying other than "?" to begin TX.
The problem is: Why $10 on MISO (or other stupid values)
Here is my code:
'*  Name    : master.BAS                                      *
'*  Author  : Herve Helleboid                                   *
'*  Notice  : Copyright (c) 2013 HYTEM                          *
'*  Date    : 02/11/2013                                        *
DEFINE OSC 64
TRISA = %00000000
TRISB = %00000000
TRISC = %10010000
TRISD = %10000000
TRISE = %00000000
ANSELA = %00000000
ANSELB = %00000000
ANSELC = %00000000
ANSELD = %00000000
ANSELE = %00000000
' configuration USART2 (communication avec FAV)
RCSTA2 = $90 ' Enable serial port & continuous receive
TXSTA2 = $20 ' Enable transmit, BRGH = 0
SPBRG2 = 77  ' 9600 Baud @ 48MHz, 0,16%
' configuration USART1 (communication RS232 externe)
RCSTA1 = $90 ' Enable serial port & continuous receive
TXSTA1 = $20 ' Enable transmit, BRGH = 0
SPBRG1 = 103 ' 9600 Baud @ 64MHz, 0,16%
SSPEN VAR SSP1CON1.5   ' SSP Enable bit
CKP   VAR SSP1CON1.4   ' Clock Polarity Select
SMP   VAR SSP1STAT.7  ' Data input sample phase
CKE   VAR SSP1STAT.6  ' Clock Edge Select bit
SSPIF VAR PIR1.3     ' SPI interrupt flag
SS0   var PORTB.3
SS1   VAR PORTB.1
SS2   VAR PORTC.2
SS3   VAR PORTC.1
LED   VAR PORTE.0
slave var byte
i     VAR BYTE           ' loop counter
a     VAR BYTE[6]        ' Holds characters read from slave
HIGH SS0            'slaves are waiting (slave select pin)
HIGH SS1
HIGH SS2
HIGH SS3
HIGH LED
PAUSE 300
LOW LED
pause 300
hserout ["rdy",13,10]
SSP1CON1 = %00100010
   SSPIF = 0         ' clear buffer full status
mainloop:
   GoSub getdata     ' initiate conversion and receive data
   hserout ["lst ",STR a\7,13,10] ' display received string
   high SS0
   Pause 500
   toggle led
   GoTo mainloop     ' do it forever
getdata:
   low SS0
   pauseus 10
   SSPBUF = "?"      ' send ? to start conversion
   GOSUB letclear    ' wait for buffer to clear
   IF SSPBUF<>"!" Then getdata ' wait for reply (!)
   For i = 0 to 6    ' loop for 7 characters
     SSPBUF = 0      ' write to SSPBUF to start clock
     GOSUB letclear  ' wait for receipt
     a[i] = SSPBUF   ' store received character in array
   Next i            ' get next character
letclear:
   IF SSPIF = 0 Then letclear ' wait for SPI interupt flag 1=TRx complet must be cleared
   PauseUs 25         ' 25uS fudge factor
   SSPIF = 0          ' reset flag
and
' Name        : SPISLAVE.pbp
' Compiler    : PICBASIC PRO Compiler 2.6
' Assembler   : PM or MPASM
' pic18f45k22 @ 16MHz PLLx4 = 64MHz
DEFINE OSC 64
TRISA = %00100000
TRISB = %00000000
TRISC = %10011000
TRISD = %10001000
TRISE = %00000000
ANSELA = %00000000
ANSELB = %00000000
ANSELC = %00000000
ANSELD = %00001000
ANSELE = %00000000
' Allocate RAM
dataout VAR BYTE[8]   ' Data out array
SSPIF   VAR PIR1.3    ' interrupt flag - last bit set
a       VAR BYTE[6]   ' Holds 6 characters of data
led     var PORTA.4
way     var byte      'n° de voie
'   SSP1CON1 = %00000101 ' configure SPI slave, no SS
SSP1CON1 = %00000100 ' configure SPI slave with SS
CKP = 0            ' clock idle low
CKE = 0            ' transmit on idle to active transition
SSPIF = 0          ' clear SPI interrupt
SMP = 0            ' sample in middle of data
SPBRG1 = 25                ' 38400 Baud @ 64MHz, 0,16%
DEFINE ADC_BITS  8     ' ADCIN resolution  (Bits)
DEFINE ADC_CLOCK 7     ' ADC clock source  (Frc)
DEFINE ADC_SAMPLEUS 11 ' ADC sampling time (uSec)
   dataout[0] = 87   ' Preset output     WAY0625
   dataout[1] = 65
   dataout[2] = 89
   dataout[3] = 48
   dataout[4] = 54
   dataout[5] = 50
   dataout[6] = 53
HIGH LED
PAUSE 300
LOW LED
ADCIN 23,way
IF way < 30 then
way = 48               'way 0 for 470R
goto mainloop
IF way < 60 then
way = 49               'way 1 for 2K2
goto mainloop
IF way < 90 then
way = 50               'way 2 for 3K9
goto mainloop
way = 51               'way 3 for 10K
mainloop:
   SSPEN = 0          ' disable/enable SSP to reset port
   SSPEN = 1
   SSPBUF = "!"       ' send reply   $21  dec = 33
   GoSub letclear     ' wait for byte received
   IF (SSPBUF <> "?") Then mainloop ' wait for ? to start conversion
   toggle led
   For i = 0 to 6     ' loop for 7 array locations
       SSPBUF = dataout[i] ' send array variable
       GoSub letclear ' wait until buffer ready
   Next i             ' next location
   goto mainloop
letclear:
   IF SSPIF = 0 Then letclear ' wait for interrupt flag
Any idea ? Someone can help ?
herve
