PIC32 developer
Results 1 to 3 of 3
Thread: PIC32 developer
    Default PIC32 developer
    I am kind of in a bind. I have a board that has three UART TX/RX channels. Ideally I would like to be able to use interrupts and hardware UARTS on all input/outputs. I can only find PIC chips with two hardware input/outputs that PIC BASIC PRO Supports so I need to go the PIC32 route I think. I have the code handled for a PIC18 series. I need someone that can make up code utilizing hardware UARTs on a PIC 32. Basically convert my code and add a couple of interrupts. I am traveling alot this next couple of weeks, if you are interested and capable, please email me at [email protected]. I am not sure of the protocol on this forum for soliciting paid work, so I hope I am not stepping on anyones toes. I just don't have the time right now to learn the PIC32 and the other outfit offering BASIC on a PIC32 platform.
    Default Re: PIC32 developer
    I was going to say that the ARE 18F parts with 4 USARTS available (18F67J94 for example) but, as you obviously already HAVE done, I checked the device support list and PBP does not support them....
    An alternative approach might be to use an external UART chip, interfaced to the PIC thru the MSSP module. Just a quick Google search turned up the MAX3107 as an example but there will be others I'm sure.
    Thanks for the suggestion
  1. PIC32 32-bit MCUs Being Supported
    By WaveMan in forum mel PIC BASIC Pro
    Last Post: - 25th March 2012, 17:18
  2. New software/hardware developments with PIC32 devices
    By ScaleRobotics in forum Off Topic
    Last Post: - 16th January 2012, 03:35
  3. MikroElectronika releases PIC32 compiler beta versions
    Last Post: - 17th February 2011, 16:41
  4. PBP PIC32 series support?
    By foss in forum mel PIC BASIC Pro
    Last Post: - 18th August 2008, 12:10
