Pic FPU
Results 1 to 10 of 10
Thread: Pic FPU
Threaded View
  1. #2
    Default Re: Pic FPU
    That's exactly what the uM-FPU does ... and a lot more.
    It's made from a dsPIC.
    They are about $20 each.
    But if you consider the time it will take you to recreate one (several months) then they're extremely cheap.
    It's pretty cool, because it has a utility that writes your PBP side code for you.
    I've only used it once for a Quaternion to Euler Angle convertor, but it worked great.
    You enter math like ...
    X = (2 * qYF * qWF) - (2 * qXF * qZF)
    Y = 1 - ((2 * (qYF * qYF)) - (2 * (qZF * qZF)))
    heading = DEGREES(ATAN2(X,Y))
    attitude = DEGREES(asin((2*qXF*qYF) + (2*qZF*qWF)))
    X = (2 * qXF * qWF) - (2 * qYF * qZF)
    Y = 1 - ((2 * (qXF * qXF)) - (2 * (qZF * qZF)))
    banking = DEGREES(ATAN2(X,Y))
    Angle = heading * 10
    And it spits out PBP code like this ...
      ' X = (2 * qYF * qWF) - (2 * qXF * qZF)
      I2CWRITE Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [SELECTA, X, LEFT, FSETI, 2, FMUL, qYF,_
        FMUL, qWF, RIGHT, FSET0, LEFT, FSETI, 2, FMUL, qXF, FMUL, qZF, RIGHT, FSUB0]
      ' Y = 1 - ((2 * (qYF * qYF)) - (2 * (qZF * qZF)))
      I2CWRITE Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [SELECTA, Y, FSETI, 1, LEFT, LEFT,_
        FSETI, 2, LEFT, FSET, qYF, FMUL, qYF, RIGHT, FMUL0, RIGHT, FSET0, LEFT,_
        FSETI, 2, LEFT, FSET, qZF, FMUL, qZF, RIGHT, FMUL0, RIGHT, FSUB0, RIGHT,_
        FSUB0]
      ' heading = DEGREES(ATAN2(X,Y))
      I2CWRITE Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [SELECTA, heading, LEFT, LEFT, FSET, X,_
        ATAN2, Y, RIGHT, FSET0, DEGREES, RIGHT, FSET0]
      ' attitude = DEGREES(asin((2*qXF*qYF) + (2*qZF*qWF)))
      I2CWRITE Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [SELECTA, attitude, LEFT, LEFT, LEFT,_
        FSETI, 2, FMUL, qXF, FMUL, qYF, RIGHT, FSET0, LEFT, FSETI, 2, FMUL, qZF,_
        FMUL, qWF, RIGHT, FADD0, ASIN, RIGHT, FSET0, DEGREES, RIGHT, FSET0]
      ' X = (2 * qXF * qWF) - (2 * qYF * qZF)
      I2CWRITE Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [SELECTA, X, LEFT, FSETI, 2, FMUL, qXF,_
        FMUL, qWF, RIGHT, FSET0, LEFT, FSETI, 2, FMUL, qYF, FMUL, qZF, RIGHT, FSUB0]
      ' Y = 1 - ((2 * (qXF * qXF)) - (2 * (qZF * qZF)))
        FSETI, 2, LEFT, FSET, qXF, FMUL, qXF, RIGHT, FMUL0, RIGHT, FSET0, LEFT,_
        FSUB0]
      ' banking = DEGREES(ATAN2(X,Y))
      I2CWRITE Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [SELECTA, banking, LEFT, LEFT, FSET, X,_
      ' Angle = heading * 10
      I2CWRITE Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [SELECTA, 0, LEFT, FSET, heading,_
        FMULI, 10, RIGHT, FIX]
      GOSUB Fpu_Wait
      I2CWRITE Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [LREAD0]
      GOSUB Fpu_ReadDelay
      I2CREAD Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [Angle(3), Angle(2), Angle(1), Angle(0)]
    There are some variables to set up too.
    The chip does the rest.
  1. FPU for pic
    By Art in forum General
    Last Post: - 12th May 2008, 11:51
  2. High Speed Serial Comm PC - PIC and PIC - PIC
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 16th January 2007, 21:55
