Simplest hardware and code to blink a LED with PIC18F4620
Results 1 to 12 of 12
    Default Re: Simplest hardware and code to blink a LED with PIC18F4620
    I hope you don't expect to see the led flash with naked eyes ,
    with a pause 10 the led will just look a bit dim, to view with eyes try pause 500 at least
    Hi Richard,
    Thanks for your time in looking at this. I am using a scope so 10 mS is very visible. I use the melabs U2 USB programmer and manually set the config fuses as per the table at the top of my program. I force all pins to be digital via the ADCON1 statement ADCON1 = %00001111.
    In the attached code, I have followed your advice and loaded the device reference file then removed the ';' character where appropriate to activate that line. Still no joy, nothing on the ClkOut line or the LED lines. Reset is pulled high by 1k to 5V and there is +5 to both Vdd pins.
    I have 3 spaces before #CONFIG - is this acceptable or must #CONFIG appear in column 1
    #CODE
    data @0, "Wet ver b 3 Nov 2013 "
    'Internal 8 MHz clock. INTIO1 Internal Oscillator with FOSC/4 output
    'on RA6 and I/O on RA7.
    '******************* Configuration fuses ***************************
    ' Device = PIC18F4620
    ' Osc = INTIO1 (ClkOut), FSCM = En, Int Ext Switch = En, PwrUpTmr = En,
    ' BrownOut = Dis, BrwnOut Volt = 2, WDT = Dis, WDT PostScaler = 512
    ' CCP2 on RC1, PortB Rst = Digital, LowPwr Tmr1 Osc = Higher power,
    ' MCLR = Reset, Stack Over/Under = En, LowVoltProg = Dis,
    ' Enhanced CPU = Dis, ALL FOLLOWING set to Not Protected.
    '''''''''''''''''''''''''' ex Richard ''''''''''''''''''''''''''''''
    ; Oscillator Selection bits
    CONFIG OSC = INTIO7 ;Internal oscillator block, CLKOUT function on RA6, port function on RA7
    ; CONFIG OSC = INTIO67 ;Internal oscillator block, port function on RA6 and RA7
    ; CONFIG OSC = RCIO6 ;External RC oscillator, port function on RA6
    ; CONFIG OSC = HSPLL ;HS oscillator, PLL enabled (Clock Frequency = 4 x FOSC1)
    ; CONFIG OSC = ECIO6 ;EC oscillator, port function on RA6
    ; CONFIG OSC = EC ;EC oscillator, CLKOUT function on RA6
    ; CONFIG OSC = RC ;External RC oscillator, CLKO function on RA6
    ; CONFIG OSC = HS ;HS oscillator
    ; CONFIG OSC = XT ;XT oscillator
    ; CONFIG OSC = LP ;LP oscillator
    ; Fail-Safe Clock Monitor Enable bit
    ; CONFIG FCMEN = ON ;Fail-Safe Clock Monitor enabled
    CONFIG FCMEN = OFF ;Fail-Safe Clock Monitor disabled
    ; Internal/External Oscillator Switchover bit
    ; CONFIG IESO = ON ;Oscillator Switchover mode enabled
    CONFIG IESO = OFF ;Oscillator Switchover mode disabled
    ; Power-up Timer Enable bit
    CONFIG PWRT = OFF ;PWRT disabled
    ; CONFIG PWRT = ON ;PWRT enabled
    ; Brown-out Reset Enable bits
    CONFIG BOREN = SBORDIS ;Brown-out Reset enabled in hardware only (SBOREN is disabled)
    ; CONFIG BOREN = NOSLP ;Brown-out Reset enabled in hardware only and disabled in Sleep mode (SBOREN is disabled)
    ; CONFIG BOREN = ON ;Brown-out Reset enabled and controlled by software (SBOREN is enabled)
    ; CONFIG BOREN = OFF ;Brown-out Reset disabled in hardware and software
    ; Brown Out Reset Voltage bits
    CONFIG BORV = 3 ;Minimum setting
    ; CONFIG BORV = 2 ;
    ; CONFIG BORV = 1 ;
    ; CONFIG BORV = 0 ;Maximum setting
    ; Watchdog Timer Enable bit
    CONFIG WDT = ON ;WDT enabled
    ; CONFIG WDT = OFF ;WDT disabled (control is placed on the SWDTEN bit)
    ; Watchdog Timer Postscale Select bits
    ; CONFIG WDTPS = 32768 ;1:32768
    ; CONFIG WDTPS = 16384 ;1:16384
    ; CONFIG WDTPS = 8192 ;1:8192
    ; CONFIG WDTPS = 4096 ;1:4096
    ; CONFIG WDTPS = 2048 ;1:2048
    ; CONFIG WDTPS = 1024 ;1:1024
    CONFIG WDTPS = 512 ;1:512
    ; CONFIG WDTPS = 256 ;1:256
    ; CONFIG WDTPS = 128 ;1:128
    ; CONFIG WDTPS = 64 ;1:64
    ; CONFIG WDTPS = 32 ;1:32
    ; CONFIG WDTPS = 16 ;1:16
    ; CONFIG WDTPS = 8 ;1:8
    ; CONFIG WDTPS = 4 ;1:4
    ; CONFIG WDTPS = 2 ;1:2
    ; CONFIG WDTPS = 1 ;1:1
    ; CCP2 MUX bit
    CONFIG CCP2MX = PORTC ;CCP2 input/output is multiplexed with RC1
    ; CONFIG CCP2MX = PORTBE ;CCP2 input/output is multiplexed with RB3
    ; PORTB A/D Enable bit
    ; CONFIG PBADEN = ON ;PORTB<4:0> pins are configured as analog input channels on Reset
    CONFIG PBADEN = OFF ;PORTB<4:0> pins are configured as digital I/O on Reset
    ; Low-Power Timer1 Oscillator Enable bit
    ; CONFIG LPT1OSC = ON ;Timer1 configured for low-power operation
    CONFIG LPT1OSC = OFF ;Timer1 configured for higher power operation
    ; MCLR Pin Enable bit
    CONFIG MCLRE = ON ;MCLR pin enabled; RE3 input pin disabled
    ; CONFIG MCLRE = OFF ;RE3 input pin enabled; MCLR disabled
    ; Stack Full/Underflow Reset Enable bit
    CONFIG STVREN = ON ;Stack full/underflow will cause Reset
    ; CONFIG STVREN = OFF ;Stack full/underflow will not cause Reset
    ; Single-Supply ICSP Enable bit
    ; CONFIG LVP = ON ;Single-Supply ICSP enabled
    CONFIG LVP = OFF ;Single-Supply ICSP disabled
    ; Extended Instruction Set Enable bit
    ; CONFIG XINST = ON ;Instruction set extension and Indexed Addressing mode enabled
    CONFIG XINST = OFF ;Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
    ; Background Debugger Enable bit
    CONFIG DEBUG = OFF ;Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
    ; CONFIG DEBUG = ON ;Background debugger enabled, RB6 and RB7 are dedicated to In-Circuit Debug
    ; Code Protection bit
    CONFIG CP0 = OFF ;Block 0 (000800-003FFFh) not code-protected
    ; CONFIG CP0 = ON ;Block 0 (000800-003FFFh) code-protected
    CONFIG CP1 = OFF ;Block 1 (004000-007FFFh) not code-protected
    ; CONFIG CP1 = ON ;Block 1 (004000-007FFFh) code-protected
    CONFIG CP2 = OFF ;Block 2 (008000-00BFFFh) not code-protected
    ; CONFIG CP2 = ON ;Block 2 (008000-00BFFFh) code-protected
    CONFIG CP3 = OFF ;Block 3 (00C000-00FFFFh) not code-protected
    ; CONFIG CP3 = ON ;Block 3 (00C000-00FFFFh) code-protected
    ; Boot Block Code Protection bit
    CONFIG CPB = OFF ;Boot block (000000-0007FFh) not code-protected
    ; CONFIG CPB = ON ;Boot block (000000-0007FFh) code-protected
    ; Data EEPROM Code Protection bit
    CONFIG CPD = OFF ;Data EEPROM not code-protected
    ; CONFIG CPD = ON ;Data EEPROM code-protected
    ; Write Protection bit
    CONFIG WRT0 = OFF ;Block 0 (000800-003FFFh) not write-protected
    ; CONFIG WRT0 = ON ;Block 0 (000800-003FFFh) write-protected
    CONFIG WRT1 = OFF ;Block 1 (004000-007FFFh) not write-protected
    ; CONFIG WRT1 = ON ;Block 1 (004000-007FFFh) write-protected
    CONFIG WRT2 = OFF ;Block 2 (008000-00BFFFh) not write-protected
    ; CONFIG WRT2 = ON ;Block 2 (008000-00BFFFh) write-protected
    CONFIG WRT3 = OFF ;Block 3 (00C000-00FFFFh) not write-protected
    ; CONFIG WRT3 = ON ;Block 3 (00C000-00FFFFh) write-protected
    ; Configuration Register Write Protection bit
    CONFIG WRTC = OFF ;Configuration registers (300000-3000FFh) not write-protected
    ; CONFIG WRTC = ON ;Configuration registers (300000-3000FFh) write-protected
    ; Boot Block Write Protection bit
    CONFIG WRTB = OFF ;Boot Block (000000-0007FFh) not write-protected
    ; CONFIG WRTB = ON ;Boot Block (000000-0007FFh) write-protected
    ; Data EEPROM Write Protection bit
    CONFIG WRTD = OFF ;Data EEPROM not write-protected
    ; CONFIG WRTD = ON ;Data EEPROM write-protected
    ; Table Read Protection bit
    CONFIG EBTR0 = OFF ;Block 0 (000800-003FFFh) not protected from table reads executed in other blocks
    ; CONFIG EBTR0 = ON ;Block 0 (000800-003FFFh) protected from table reads executed in other blocks
    CONFIG EBTR1 = OFF ;Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
    ; CONFIG EBTR1 = ON ;Block 1 (004000-007FFFh) protected from table reads executed in other blocks
    CONFIG EBTR2 = OFF ;Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
    ; CONFIG EBTR2 = ON ;Block 2 (008000-00BFFFh) protected from table reads executed in other blocks
    CONFIG EBTR3 = OFF ;Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks
    ; CONFIG EBTR3 = ON ;Block 3 (00C000-00FFFFh) protected from table reads executed in other blocks
    ; Boot Block Table Read Protection bit
    CONFIG EBTRB = OFF ;Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    ; CONFIG EBTRB = ON ;Boot Block (000000-0007FFh) protected from table reads executed in other blocks
    ''''''''''''''''''''''''''''''''' end ex Richard ''''''''''''''''''''''''''''
    '********************** DATA and DEFINES ***************************
    DEFINE OSC 8
    'Select INTIO1 (ClkOut) in the configuration menu at programming.
    'Use OSCCON to select frequency & select internal oscillator block
    'Use CRO to see if any ClkOut visible on Osc2/ClkOut pin 14(40) or 31(44)
    Initialise:
    LED1 var PORTE.1 'LATE.1 does not work either
    LED2 var PORTE.2 'LATE.2 does not work either
    TRISE = %00001000 'make sure PSP is OFF & MCLR active
    PORTE = %00001000 '
    ' OSCCON = %11111110 ' 8 MHz Internal Osc Block
    ' ' 0------- IDLEN 0 = enters SLEEP on Sleep command = 4 uA
    ' ' 1------- IDLEN 1 = enters IDLE on Sleep command and draws 550 uA
    ' ' -111---- IRCF <2:0> Int Osc freq select 111 = 8 MHz
    ' ' -110---- IRCF <2:0> Int Osc freq select 110 = 4 MHz
    ' ' -101---- 2 MHz
    ' ' -100---- 1 MHz
    ' ' -011---- 500 kHz
    ' ' -010---- 250 kHz
    ' ' -010---- 125 kHz
    ' ' -000---- 31 kHz
    ' ' ----0--- OSTS Osc Startup Status - read only - ignore
    ' ' -----0-- IOFS IntOsc Freq Stable - read only - ignore
    ' ' ------00 System Clock Select 00 = Primary Osc
    ' ' ------01 Secondary (Timer1) oscillator
    ' ' ------1x Internal oscillator block
    ' WDTCON = %00000001 ' enables SWDT - needs WDT OFF in config
    ' ' xxxxxxx1 SWDTEN software controlled WDT enabled
    ADCON0 = %00000000 ' ADC OFF
    ' xx0000-- CH<3:0> select analog channels
    ' ------0- 1 = Go, 0 = Done
    ' -------0 1 = ADC ON, 0 = ADC OFF
    ADCON1 = %00001111 'VRef = Vdd, Vss, All ports digital
    ' configures all digital
    ' 00------ Unimplemented
    ' --00---- VCFG<1:0> Select Vcc & Gnd as ADC references
    ' ----1111 PCFG<3:0> A/D Port configuration see "register 19-1"
    ' ADCON2 = %00111111 'Left just (=8 bit), ADacq time = 20 Tad, ADClk = Frc
    ' 0------- ADFM 0 = Left Justified 8 bit mode
    ' -x111--- ACQ<2:0> A/D aquisition time = 20 Tad
    ' -----111 ADCS<2:0> A/D conversion clock select = Fr/c
    CMCON = %00000111 ' Comparators OFF
    ' 00------ No comparator outputs
    ' --00---- No inversion on outputs
    ' ----0--- Vin to pins AN0 & AN1
    ' -----111 Comparators OFF
    MainLoop:
    High LED1 '
    high led2
    Pause 250 '
    Low LED1 '
    low led2
    Pause 250 '
    Goto mainloop '
    ENDCODE
    Any more suggestions or comments?
    BrianT
    Some observations. It seems the #CONFIG and #ENDCONFIG can be in column 1 but all the other values must be indented.
    When I hit 'compile program' the code all compiles but when I check the CONFIG data by hitting the"C" button then all my last, hand entered, values are displayed. How can I force the new #CONFIG vales to take precedence?
    BrianT
    In the programmer software (meProg), go to Options and make sure Update Configuration from File is checked.
  1. Replies: 12
    Last Post: - 1st November 2013, 13:32
  2. Led blink and interrupt
    By critix in forum mel PIC BASIC Pro
    Last Post: - 24th April 2012, 11:31
  3. PIC18F4620 , what's wrong with my A/D converter code
    By Porcusoru in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2009, 20:35
  4. Newbie: Trying to blink a LED
    By JackPollack in forum General
    Last Post: - 29th March 2007, 06:31
  5. Can't get a 12F629 to blink a led
    By Sharky in forum mel PIC BASIC Pro
    Last Post: - 27th June 2005, 11:28
