Addressing ports via offset using lookup command
Results 1 to 11 of 11
    Feb 2012
    PERTH AUSTRALIA
    Default Re: Addressing ports via offset using lookup command
    well it compiles ,after making the change to lookup2 , and portoffset to a word variable
    but ill have to wait for the pcbs to arrive to test it
    cheers hendrick
    When you are using the "Bit Offset from Port" method, it is using "BIT Array" operations internally.
    BIT array's have a limit of 256 elements.
    Giving it a WORD sized offset will not work.
    It will compile using a WORD, but it will only use the LowByte of that value.
  1. PicBasic Lookup command
    By queenidog in forum mel PIC BASIC
    Last Post: - 18th June 2016, 21:54
  2. 10bit ADC with offset on 16F88
    By Amoque in forum mel PIC BASIC Pro
    Last Post: - 1st April 2012, 16:11
  3. DS1820 Negative Numbers and OffSet
    By gadelhas in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2011, 22:53
  4. dt int timer1 ignores offset value
    By DDDvvv in forum mel PIC BASIC Pro
    Last Post: - 15th June 2010, 10:53
  5. Offset to variable howto ?
    Last Post: - 3rd October 2008, 10:36
