PIC18F14K50 and USBin
Results 1 to 10 of 10
    Jun 2008
    Varese , Italy
    Default Re: PIC18F14K50 and USBin
    Hi Derrel,
    I would like to use the USB connection to the PC for the first time since I do not have the serial port available to me anymore.
    I am asking if there is a complete sample program that shows me everything on the USB usage to exchange data to and from the PC.
    Are there some hardware advices ? or just use d+ and d- to the PIC ?
    The pic is the 184550 and the compiler is PBP 2.50.
    Thanks in advance for the assistance on the matter.
    Best regards,
    Ambrogio IW2FVO
    To replace a COM port with USB, you'll want to use the CDC protocol.
    Start with this thread ...
    USB CDC Communications for Dummies!
    http://www.picbasic.co.uk/forum/showthread.php?t=5806
    Jun 2008
    Varese , Italy
    Thanks Derrel,
    I red a lot of posts as indicated.
    I am asking if there is a "final summary "available in which the final hardware and software configuration is described.
    In my personal case I shall use the 18f4455 device and the crystal oscillator that could be 20 Mhz or 4 MHz. No bus power will be used.
    What will be the configuration set up ? ( include, define ... etc )
    What is the program to callup every cycle in my PBP program to comunicate and to receive USB data?
    I am sorry but reading all the above posts I still not have a clear understanding.
    Thanks for any help.
    Best regards,
    Ambrogio
    iw2fvo
    May 2012
    Moscow, Russia
    I have to note that that thread doesn't write anything useful about clock settings. The line "DEFINE OSC 48" looks very naively. :-) It is not enough.
    By the way I managed partly to solve my problem. I found that if I set the system clock as high as 48 MHz then the CPU functions unstable. I got some other problems with another type of operations besides the USB interface.
    Now my setting are the following:
    • clock frequency- 12 Mhz;
    • 4xPLL -enabled;
    • CPUDIV=10;
    That is the system clock is 16 MHz and USB clock is 48 MHz.
    But I had no time to check USB operations at these conditions. I'll check and will report lately.
    Everybody wants to have a job but nobody wants to work.
    Maybe it would help if you read the whole thread, or at least to post #14
    http://www.picbasic.co.uk/forum/show...8359#post68359
    And the data sheet is VERY helpful too.
    May 2012
    Moscow, Russia
    Of course, it is very helpful!
    Still not checked USB with new clock settings... It might happen tonight.
  1. Pic18f14k50
    By JoeyWallice in forum mel PIC BASIC
    Last Post: - 23rd October 2012, 12:13
  2. Pic18f14k50
    Last Post: - 17th October 2012, 03:16
  3. Pic18F14K50 when?
    By Free_Flow in forum PBP Wish List
    Last Post: - 17th August 2009, 03:36
  4. Usbin and hserin
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 27th October 2007, 16:26
  5. Need help with USBIN
    Last Post: - 13th June 2007, 19:51
