PIC18F14K50 and USBin
Results 1 to 10 of 10
    May 2012
    Moscow, Russia
    Default PIC18F14K50 and USBin
    Hi!
    I'm trying to use an internal USB-port (PIC18F14K50) in CDC-mode (USB-COM emulation). It is strange but the USBIN command reads only the first byte sent from the host. The other bytes are I don't know where from.
    I tried to write to the buffer initial meanings. It is seen that the buffer changes. But the result is very strange.
    Of course I could send byte-after-byte but I wonder why the USB-port functions not properly, not as described in the PBPpro manual.
    The part of the program:
    Variant 1
    inloop:
    cnt = 1
    USBService
    USBIn 3, buffer, cnt, inloop
    outloop:
    USBService
    USBOut 3, buffer, 1, outloop
    Goto inloop
    I send "ABC" via USB-COM-port and receive "ABC" back.
    Variant 2
    inloop:
    cnt = 3
    USBService
    outloop:
    USBService
    USBOut 3, buffer, 3, outloop
    Goto inloop
    I send "ABC" via USB-COM-port and receive "AÆBÆCÆ" back. It can be seen that every right symbol accompanied with some others. It looks like USBIN receives all the rest symbols in the buffer after the first byte is sent from the host.
    Does this apply only to the PIC18F14K50? I looked through the forum and didn't find anything like my problem.
    Everybody wants to have a job but nobody wants to work.
    Default Re: PIC18F14K50 and USBin
    The USBIN command returns the number of bytes received in the cnt variable.
    You should use that variable for the number of bytes to be sent by USBOUT.
    USBOut 3, buffer, cnt, outloop
    Otherwise, if it only receives 1 byte, and sends 3 bytes, 2 of them will be garbage characters left over in the buffer.
    May 2012
    Moscow, Russia
    I seem to explain badly.
    The command USBIN doesn't write bytes to the buffer one after another.
    I send 3 bytes and hope that all of them would be sent into the buffer (array of 3). But really after the first received byte the program writes something to the other 2 buffer bytes and begins receiving next byte. Then adds to it 2 its own etc...
    One fact is clear: all those nowhere bytes are the same every time they are written. So I think there is some cause why those strange bytes appeared.
    Quote Originally Posted by ybosco View Post
    With CDC, you have no control over how many bytes are received at a time. That depends on the operating system of the PC.
    You may get 3 bytes, or you may only get 1, you have to account for the number of bytes received.
    Your belief that USBIN is writing characters that it didn't receive, is completely incorrect.
    Those characters are already in the buffer array.
    If you clear the array before doing the USBIN you will see the difference.
    Read Post #2 again, which will fix your sample code.
    Jun 2008
    Varese , Italy
    Hi Derrel,
    I would like to use the USB connection to the PC for the first time since I do not have the serial port available to me anymore.
    I am asking if there is a complete sample program that shows me everything on the USB usage to exchange data to and from the PC.
    Are there some hardware advices ? or just use d+ and d- to the PIC ?
    The pic is the 184550 and the compiler is PBP 2.50.
    Thanks in advance for the assistance on the matter.
    Best regards,
    Ambrogio IW2FVO
    To replace a COM port with USB, you'll want to use the CDC protocol.
    Start with this thread ...
    USB CDC Communications for Dummies!
    http://www.picbasic.co.uk/forum/showthread.php?t=5806
  1. Pic18f14k50
    By JoeyWallice in forum mel PIC BASIC
    Last Post: - 23rd October 2012, 12:13
  2. Pic18f14k50
    Last Post: - 17th October 2012, 03:16
  3. Pic18F14K50 when?
    By Free_Flow in forum PBP Wish List
    Last Post: - 17th August 2009, 03:36
  4. Usbin and hserin
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 27th October 2007, 16:26
  5. Need help with USBIN
    Last Post: - 13th June 2007, 19:51
