Pic FPU
Results 1 to 10 of 10
Thread: Pic FPU
    Aug 2003
    Default Pic FPU
    Hi Guys,
    Has anyone considered writing an FPU for a pic to run side by side another pic
    so that a PBP program can request results for floating point operations (trig functions) ?
    I figure a 4 or 8 bit interface to a fast chip would be much faster than having the
    same chip doing cordic trig, but of course, would add expense by requiring another chip.
    I'm working on a project currently for dsPic33FJ128GP802, which is pin for pin compatible
    with some other devices of more or less specification such as memory space.
    These kind of operations are child's play in Microchip's C, but I never thought to make a
    slave math device for another pic running a PBP program.
    Only issue is the device I'm using is 3.6Volts (or 3.3).. I didn't have to make the circuit,
    I just have to expand on the thing which is a single chip web server.
    I haven't looked into a PBP compatible pic that operates on the lower voltage.
    Are these abundant?
    Cheers, B.
    Default Re: Pic FPU
    That's exactly what the uM-FPU does ... and a lot more.
    It's made from a dsPIC.
    They are about $20 each.
    But if you consider the time it will take you to recreate one (several months) then they're extremely cheap.
    It's pretty cool, because it has a utility that writes your PBP side code for you.
    I've only used it once for a Quaternion to Euler Angle convertor, but it worked great.
    You enter math like ...
    X = (2 * qYF * qWF) - (2 * qXF * qZF)
    Y = 1 - ((2 * (qYF * qYF)) - (2 * (qZF * qZF)))
    heading = DEGREES(ATAN2(X,Y))
    attitude = DEGREES(asin((2*qXF*qYF) + (2*qZF*qWF)))
    X = (2 * qXF * qWF) - (2 * qYF * qZF)
    Y = 1 - ((2 * (qXF * qXF)) - (2 * (qZF * qZF)))
    banking = DEGREES(ATAN2(X,Y))
    Angle = heading * 10
    And it spits out PBP code like this ...
      ' X = (2 * qYF * qWF) - (2 * qXF * qZF)
      I2CWRITE Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [SELECTA, X, LEFT, FSETI, 2, FMUL, qYF,_
        FMUL, qWF, RIGHT, FSET0, LEFT, FSETI, 2, FMUL, qXF, FMUL, qZF, RIGHT, FSUB0]
      ' Y = 1 - ((2 * (qYF * qYF)) - (2 * (qZF * qZF)))
      I2CWRITE Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [SELECTA, Y, FSETI, 1, LEFT, LEFT,_
        FSETI, 2, LEFT, FSET, qYF, FMUL, qYF, RIGHT, FMUL0, RIGHT, FSET0, LEFT,_
        FSETI, 2, LEFT, FSET, qZF, FMUL, qZF, RIGHT, FMUL0, RIGHT, FSUB0, RIGHT,_
        FSUB0]
      ' heading = DEGREES(ATAN2(X,Y))
      I2CWRITE Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [SELECTA, heading, LEFT, LEFT, FSET, X,_
        ATAN2, Y, RIGHT, FSET0, DEGREES, RIGHT, FSET0]
      ' attitude = DEGREES(asin((2*qXF*qYF) + (2*qZF*qWF)))
      I2CWRITE Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [SELECTA, attitude, LEFT, LEFT, LEFT,_
        FSETI, 2, FMUL, qXF, FMUL, qYF, RIGHT, FSET0, LEFT, FSETI, 2, FMUL, qZF,_
        FMUL, qWF, RIGHT, FADD0, ASIN, RIGHT, FSET0, DEGREES, RIGHT, FSET0]
      ' X = (2 * qXF * qWF) - (2 * qYF * qZF)
      I2CWRITE Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [SELECTA, X, LEFT, FSETI, 2, FMUL, qXF,_
        FMUL, qWF, RIGHT, FSET0, LEFT, FSETI, 2, FMUL, qYF, FMUL, qZF, RIGHT, FSUB0]
      ' Y = 1 - ((2 * (qXF * qXF)) - (2 * (qZF * qZF)))
        FSETI, 2, LEFT, FSET, qXF, FMUL, qXF, RIGHT, FMUL0, RIGHT, FSET0, LEFT,_
        FSUB0]
      ' banking = DEGREES(ATAN2(X,Y))
      I2CWRITE Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [SELECTA, banking, LEFT, LEFT, FSET, X,_
      ' Angle = heading * 10
      I2CWRITE Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [SELECTA, 0, LEFT, FSET, heading,_
        FMULI, 10, RIGHT, FIX]
      GOSUB Fpu_Wait
      I2CWRITE Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [LREAD0]
      GOSUB Fpu_ReadDelay
      I2CREAD Fpu_SDA, Fpu_SCL, Fpu_ID, 0, [Angle(3), Angle(2), Angle(1), Angle(0)]
    There are some variables to set up too.
    The chip does the rest.
    Aug 2003
    Default Re: Pic FPU
    I did figure the only difficulty is coming up with a protocol
    to speak between the two.
    Obviously have to tell it what operation to do,
    and the FPU part has to cram the float into the best possible integer.
    Was thinking simpler than that, one operation at a time, but free code in the end.
    I2C I didn't consider. Not sure if I have I2C slave code on the C side.
    Jan 2012
    Grid EN19MV
    Default Re: Pic FPU
    I was going to suggest the exact same thing.....
    So I says: "Pardon? Was that in English??" Honestly, I don't have the FAINTEST idea what that means!
    -Stephen Hawking
    Aug 2003
    Default Re: Pic FPU
    Maybe it would be easier instead to focus on gfx displays so no floats ever have to
    be transmitted, but rather, only integer screen coordinates.
    Say you wanted a clock face with hands you could send the coordinates of the
    point you want rotated, and the angle of rotation, the coordinates of the origin,
    and the chip provides the new coordinate integers.
    I know there is a clock example here, but without looking I'd say a number
    of points about the clock face are pre-defined.
    I'll bet it cannot currently have a sweeping second hand (for example).
    Default Re: Pic FPU
    Quote Originally Posted by andywpg View Post
    Probably not ...
    Quaternions were developed by an Irish mathematician, and Euler Angles (pronounced Oiler Angle) were from a Swiss mathematician.
    Play around with Digital Gyro's and Accelerometers, and you're sure to come across them.
    They are used in rotating 3D objects too.
    Default Re: Pic FPU
    Art
    As a side note is there a reason you require floats in place of Longs?
    Couldn't a Long result be used as a float by determining the decimal point by division by a multiple of 10?
    For larger values Darrel's lesser known N-Bit_MATH could be utilized.
    Norm
    Aug 2003
    Default Re: Pic FPU
    It's not the numbers that are needed, but the math,
    and in particular, of interest to me, trigonometric functions
    not implemented in PBP such as: sin, cos, tan, etc.
    needed for calculations such as distance,bearing,foot of perpendicular,
    anything to do with angles in games (ball bouncing of a wall at the inverse angle), etc.
  1. FPU for pic
    By Art in forum General
    Last Post: - 12th May 2008, 12:51
  2. High Speed Serial Comm PC - PIC and PIC - PIC
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 16th January 2007, 22:55
