Hi Babalola,
The routine I posted uses the FSR0 indirect addressing method which is not available in the 16F72. 16F72 has a single FSR register so it would be a different implementation. With Anded outputs steering the PWM should not be difficult. You can use the same phase drive signal to drive the upper MOS so only the lower MOS would be switching with your PWM.
With 20MHz clock each of your instruction takes 200nS. So servicing the interrupt, (All MOS turned off within it) and then fetching the lookup table from PBP and switching as per system flag is quite some DEAD TIME . Another way of steering the PWM is using Four Buffers each connected to individual PIC ports and 4 nos of 4.7K resistors from the PWM pin to the four ports. So you get the following output;
1. PORT pin floating (Z, as input) = PWM
2. PORT pin LOW = LOW
3. PORT pin high = High
Since you are using a demo version of PBP, I would try to find some time to get some portions compiled for you. However I am a bit stuck and behind schedule in one of my projects. So please hang on...
Anybody else out there to help... Please do.
